S-Series - Home Base
Old Jun 17, 2017 | 09:03 PM
  #1971
adam072987's Avatar
adam072987
Here is a video about the EIMTS
To enable:
Turn the ignition switch on. Push the engine off/run switch on the right handlebar to the run position (the motorcycle may be running or not running).
Push the throttle to roll-off position and hold.
See Instrument Lamps . After approximately 3 seconds, the cruise indicator lamp will either flash green (EITMS enabled) or orange (EITMS disabled).
Repeat the procedure as necessary to enable or disable EITMS.
  #1972
Fatboy16S's Avatar
Fatboy16S
Default My FB S
Been watching this thread since joining. Have gotten my S closer to mine, so here is a pic of where I have gone with it so far. A lot of nice rides posted here.
Old Jun 17, 2017 | 09:09 PM
  #1973
TeaRunner's Avatar
TeaRunner
Originally Posted by adam072987
Here is a video about the EIMTS https://www.youtube.com/watch?v=wzzhYN-vjHs .
To enable:
That procedure only works on the touring bikes. Softails require direct ECM access to turn it on/off.
Old Jun 17, 2017 | 09:30 PM
  #1974
adam072987's Avatar
adam072987
Havent tried it but those directions came right out of the Slim S manual at HD.com . That sucks.
Old Jun 17, 2017 | 09:31 PM
  #1975
adam072987's Avatar
adam072987
What exhaust is that?
Old Jun 17, 2017 | 09:40 PM
  #1976
Fatboy16S's Avatar
Fatboy16S
The EITMS on my S turns on and off exactly that way. I have played with it a few times and it is currently on being so hot here in Jersey. The exhaust are Rinehart Crossbacks. Love them!
Old Jun 17, 2017 | 09:46 PM
  #1977
adam072987's Avatar
adam072987
What do you mean played with it? Are you able to turn it on and off easily like the manual says or something else?
Just wondering I was thinking of checking mine out.
Old Jun 17, 2017 | 09:50 PM
  #1978
TeaRunner's Avatar
TeaRunner
If it says that in the manual then they finally added support for it. Enjoy it, that's new.
Rock on.
Old Jun 17, 2017 | 09:56 PM
  #1979
Fatboy16S's Avatar
Fatboy16S
I have turned it on and off and tested the function in warmer weather. Kind of makes you think something is wrong the first time it kicks on at a red light.
Old Jun 25, 2017 | 10:17 AM
  #1980
NCBANDIT's Avatar
NCBANDIT
Can any 2016 Slim S owners start your bike in gear by only pulling the clutch in before pressing the button. I have to pull in the clutch and front brake?
