Deluxe vs nostalgia???
Old Sep 30, 2015 | 06:21 PM
Greenpig's Avatar
Greenpig
Default Deluxe vs nostalgia???
I'm going to be building an evo deluxe ground up and right now I'm trying which front end to buy. So I went on Jpcycles.com and deluxe isn't even listed as an option on the models list. As far as I can tell the deluxe is designated flstn(am I wrong?) but this comes up as 'nostalgia' for example in '95 softail models. I'm confused are these the same bike??
Also nowhere on the site does it list that the front ends they do have are ' stock replica' ie fork length, tree rake, axle size etc.
My frame is a krafttech k15001 so it's 0 stretch and 30 degree rake which I assume is stock?? And isn't deluxe stock rake 32 degrees total( neck+ tree)?
Can anyone shed some light on any of this these front ends are costly and I'd hate to deal with getting the wrong parts. I want to keep most of this bike stock other than exhaust wheels( more or less parts that are independent)
Old Sep 30, 2015 | 07:15 PM
Jetfever's Avatar
Jetfever
There are people far more qualified to answer some of your questions than I.
The Deluxe IS a FLSTN. I Think the N actually stands for Nostalgia.
Opinion: The tail light on the Deluxe is the most "nostalgia" thing about the bike vs the Heritage.
I can't help on the frame and front end questions, but I found many parts from different years fit using this site:
http://partsfinder.onlinemicrofiche....ModelYear=2013
If you are looking for a Springer front end for e.g. you could look at a 2006 Springer, and compare the frame (part numbers) with a late model softail frame. You might find the frame is the same.
Good luck, I hope some qualified people chime in on your thread.
Steve
Old Sep 30, 2015 | 07:43 PM
Greenpig's Avatar
Greenpig
Thank you Steve that definitely adds a few pieces to the puzzle I appreciate the input
Old Oct 1, 2015 | 06:35 AM
cocky's Avatar
cocky
Back in the 90's, HD made a version of the heritage called the nostalgia and designated it as FLSTN. I think the moo glide was part of that FLSTN designation. They only did a few years and then roll forward to 05 and they came out with the deluxe we have now and designated it as FLSTN. Who knows why. Tail light and several other things are different between the heritage and deluxe besides the tail light. Lolly pop turnsignals and fender marker lights are just a few. Hope this helps.
Old Oct 1, 2015 | 08:07 AM
Tampa Fatboy's Avatar
Tampa Fatboy
Try using google~~~> wiki+FLSTN or Harley Davidson FLSTN+wiki
Most in here do that very same thing before replying.
Old Oct 1, 2015 | 01:16 PM
Uncle G.'s Avatar
Uncle G.
H-D brought out the FLSTN "Nostalgia" in '93. After a copyright dispute with another company over the "Nostalgia" name, they changed the name to "Special" for the following three years the bike was made ('94 thru '96). The model designation remained "FLSTN".
In '05, Harley brought out the Heritage "Deluxe", and for reasons Known only to the MoCo, they reused the model designation "FLSTN".
That's my '94 FLSTN in my avatar. It's a "Special" (and it is to me).
Old Oct 1, 2015 | 01:44 PM
nhrider1's Avatar
nhrider1
Most of the above info is correct. There are 2 FLSTN models, an Evo and a Twin Cam (2005 and up). They are similar but different models. The suspension is lowered on the Twin Cams, so the front end is most likely different.
jaylnn
May 13, 2013 02:56 AM
Sleeko
Mar 7, 2011 08:36 PM
buckwheat
May 25, 2009 11:53 AM
HarleyCamper
May 23, 2009 05:54 AM
utz
May 22, 2008 03:20 PM
