95 FLSTN circuit breakers
Old Oct 2, 2015 | 04:31 PM
RobinVegas's Avatar
RobinVegas
Stage II
Default 95 FLSTN circuit breakers
I have a 95 FLSTN and seek help. My negative battery connection loosened itself and appears to have affected one or several of the circuit breakers. Symptoms: low beam does not work, high does. Light for speedometer, left had turn signal sights, rear brake lights all are out. I have a Clymer manual with a wiring diagram...it looks like 2 of the circuit breakers may be the problem...the accessory and light breakers. The bike starts and runs; only these lights don't work. I have located the 3 circuit breakers near the on/off switch; between the gas tank halves. Two of the circuit breakers are facing outward; a third appears to be attached to the back of the top breaker. How do I replace these? Do I need to remove the plate which the ignition knop and speedometer are bolted to? How do I do this? I am stuck! Any advice you could provide would be appreciated. My home email is gobibeige@yahoo.com Thanks,
Rob in Las Vegas.
Junior_co
Jun 5, 2016 09:21 AM
vernv
May 27, 2013 11:09 AM
redwing67
Mar 2, 2012 04:31 PM
bubba78flh
Shovelhead
Jul 3, 2010 07:11 AM
Jason8643
Nov 26, 2009 09:40 PM
