Lights on after engine fires up
Old May 24, 2013 | 09:38 AM
vernv's Avatar
vernv
2nd Gear
Default Lights on after engine fires up
I am installing a light relay and diode to make the lights come on after the engine fires up. Anyone done that and has anyone needed to replace spot switch. I am considering installing relay to protect this switch but wonder if it's necessary. Also, is there any reason I would want the spot lights to go off on toggling to bright as they do now? Thanks, vernv
Old May 24, 2013 | 10:32 AM
JohnnyC's Avatar
JohnnyC
I simply disconnected the light lead from the accessory relay in my relay cluster. This allows me to fire and run the bike without the headlights being on all the time. It's a good way to allow the bike full power for cranking, and a way to put a higher charge in the battery after a start.
My spotlights are on a toggle without a relay. They are HD optional spots and I know for a fact they draw a lot of juice off the electrical. Mine are either on or off, no dim / bright modes. The toggle for them has held up just fine. I'm not much of a night rider but when running all lights, including spots there is a huge drain especially when adding brake and turn signal lights.
Old May 27, 2013 | 10:50 AM
vernv's Avatar
vernv
2nd Gear
Hi JohnnyC,
Thanks for the note. I'm not crazy on the idea of a separate switch. I would be likely to forget and not turn them on. I'm going to take a signal off the alternator and turn them on with a second relay. I'm not sure what to do about the spots being on the low beam circuit. I wonder why Harley did it that way. v
Old May 27, 2013 | 11:09 AM
JohnnyC's Avatar
JohnnyC
The spot lights operating only when low beams are on is a way to keep from overloading the electrical system. Harley wired them that way to prevent overloading the system. Bright beams and spots draw a huge amount of juice, especially when operated together.
Tapping into the electrical from anywhere other than the battery may overload the wiring your taking a tap from. Direct from battery with it's own line heavy enough to take the current draw is best. And don't forget the inline fuse to prevent damaging the battery in case of a short.
Garcia85
Apr 16, 2022 10:19 PM
Poa
Electrical/Lighting/Alarm
22
Mar 7, 2019 10:09 AM
redwing67
Mar 2, 2012 04:31 PM
kyknights
Ironhead
Apr 9, 2008 12:45 PM
bclerk
Oct 16, 2005 01:31 AM
