Engine Build
Old Oct 7, 2015 | 12:26 PM
Next In Line's Avatar
Next In Line
What do you want more of - off the line or top speed?
Old Oct 7, 2015 | 02:39 PM
gnarlyfox001's Avatar
gnarlyfox001
Both.
Old Oct 7, 2015 | 04:35 PM
Snowyone's Avatar
Snowyone
Default gettie up and go
Go for the 98" with supporting head work, cam, carb, and pipes. You'll need a little stiffer spring in the clutch to. While they are doing the heads put in some manual compression releases to save on starters, sprag clutch, and batterys. Lots of dyno sheets showing teens with this setup. My 02 with its 95 SE setup made 105hp/101 tq but the 98 wasn't on the scene yet. My current 011 Fatboy ended up being a 124 that was talked about because the 96 was such a pooch even with intake, cams, pipes. etc after the 02 95".
I did the assembly work on the 124 other than boring the cases, Timken bearing, and heads. With everything upstream and down I was into it closer to 10k. I now have a $12k bike with about $28k in it but didn't build it to sell thank heavens. The 98" would be much more cost effective at about $3k and quite an upgrade in power if your crank is up to par.
Old Dec 8, 2015 | 09:59 PM
gnarlyfox001
In the end probably gonna be ordering up a 124 kit. The 1 and done option.
ClassicBill
Jun 10, 2016 09:55 PM
gnarlyfox001
Engine Mechanical Topics
Oct 17, 2015 11:43 AM
4 inch pistons
Dec 20, 2012 08:19 PM
jrfernandez7
Aug 2, 2009 10:54 AM
jrhd1
Exhaust System Topics
11
Dec 12, 2008 10:41 PM
