Wheel Weights
Old Oct 12, 2015 | 01:18 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Originally Posted by Heritage Dee
Everyone thanks for the advice. I am a new rider (one year - 8000 miles). Just got this new bike. I will research both options, beads and ride on. sounds like ride on would invalidate my warranty if I admit to using it.....
dee
I can't see where it would void any warranty. The advantage Ride On has over beads...Ride On is also a tire sealant, not just for balance.
Old Oct 13, 2015 | 04:47 AM
peg20's Avatar
peg20
My fatboy (solid) wheels must be really out of balance themselves, as I always need a ton of weight on the rear wheel in almost the same place each time the tyre is changed. Is it possible to correct this first? Do these heavy cast wheels need a different amount of ride-on to spoked and other lighter wheels? I've never found a good reply to this question but ask it often.
Old Oct 13, 2015 | 05:58 AM
SG_Jim's Avatar
SG_Jim
The tire size determins the amount of Ride On not the style of rim.
Old Oct 13, 2015 | 06:13 AM
peg20's Avatar
peg20
But given the amount of weight that's on it, I clearly can't pull off all that and expect the same amount of rideon to work as for a lighter, less out-of-balance rim. So unless a larger amount of rideon is appropriate, it looks like I'm going to have to keep the weights anyway (or otherwise balance the rim on its own first).
Old Oct 13, 2015 | 09:56 AM
hattitude's Avatar
hattitude
I switched to ride-on after I found a couple wheel weights missing during a bike detail (stick'em still there, weight gone)..... and my first tire change had a slightly scalloped tire from being out of balance.
Ride-on was an easy install. It took longer to get the old stick on weights off. Plus, I like the fact that it will "adjust" the tire balance as the tire wears.....
I know shops cringe when told there is "slime" in the tires, but ride-on doesn't make the mess that slime does....
I've never had a wheel/tire warranty so I don't know the rules on those.. But I can't see how ride-on would void one.....
Old Oct 13, 2015 | 03:25 PM
teebeejek's Avatar
teebeejek
How does all this discussion square with the post about Dyna Beads on the front page?
Old Oct 13, 2015 | 03:33 PM
jam436's Avatar
jam436
I've been running DynaBeads on my Slim (with tubes) through two sets of tires now without issues... my indie even claims they're re-useable if you feel like retrieving them - but they're cheap enough to not even bother...
Old Oct 13, 2015 | 04:01 PM
GinsengSullivan's Avatar
GinsengSullivan
Dyna Beads!
Old Oct 13, 2015 | 04:34 PM
swifty's Avatar
swifty
I have used both. Ride on and now Dyna beads. Both do a great job, But if you have cast wheels ride on can stop a flat and get you home, For spoke wheels its dyna beads....
pat.h
Sep 28, 2014 11:03 AM
tmultra
Dec 31, 2013 05:13 PM
Subduedracer
Jul 10, 2013 01:18 PM
Henry89
May 16, 2012 04:05 PM
Cakes
Sep 2, 2007 08:35 PM
