Wanryd Front wheel.....question? Balanced?
Old May 15, 2012 | 06:49 PM
Henry89's Avatar
Henry89
Exclamation Wanryd Front wheel.....question? Balanced?
I received my 21" Wanaryd wheel on Saturday. Last night I installed it and tonight I was looking it over and there is not a single wheel weight on the wheel. Now I paid for wheel, rotors (2x) and tire mounted and balanced. Unless I'm not in the loop on some new wheel balancing technology I would say this wheel hasn't been balanced. I'm going to call Wanaryd in the morning to sort it out but the question I have is should I do a road test with the wheel installed? I'm thinking NO..don't risk it. I paid $xxxx.xx for the wheel and there shouldn't be any questionable issues. Who's to say what would happen. Has anyone else purchased a front wheel from Wanaryd? Was the wheel balanced and were there weights on the front wheel? I ordered this wheel. This thread is not to flame Wanaryd but just asking if I'm missing something. I'm going to square everything away with Wanaryd tomorrow. Thanks
Old May 15, 2012 | 07:12 PM
Fatboy Brian's Avatar
Fatboy Brian
I thought I seen were they use dyna beeds which are located inside the wheel. No cause for panic.
Old May 15, 2012 | 07:19 PM
tumorhuntr's Avatar
tumorhuntr
+1 on the dyna beads. i've had wheels balanced with them. they worked great. no need to panic.
Old May 15, 2012 | 07:22 PM
Henry89's Avatar
Henry89
Yeah....no cause to panic if you've been informed. Nothing in the box but the complete wheel....what the hell is dyna beeds? Now I might not be up to date on wheel balancing technology but I grew up working in a tire shop/re-cap shop from the age of 15 till I joined the Army at the age of 18. So what is the deal with dyna beeds?
Old May 15, 2012 | 07:25 PM
Fatboy Brian
Check out this site. It should answer your questions.
http://www.innovativebalancing.com/index.php
Old May 15, 2012 | 07:37 PM
Henry89's Avatar
Henry89
Okay....so how am I suppose to know that this wheel has dyno beeds without any documentation?
Old May 15, 2012 | 07:53 PM
1HarleyGuy1's Avatar
1HarleyGuy1
Just found a Youtube video about dyna beads from 2008. Nothing new there
1HarleyGuy1
Old May 15, 2012 | 07:58 PM
JRandall's Avatar
JRandall
Why???? Worst thing thats gonna happen is its gonna shake, big deal, then you'll know. My rear 18 has no weight on it, no beads and no shake. If it was mine I'd ride it, if it shook I'd balance it the same way we do on spindle mount front wheels on drag car. Take brake caliper off (get wheel to spin freely) jack it up, spin wheel, heavy side will go to bottom, stick on weight on the oppisite side.
Odds are it won't shake, if they mounted it they probably checked it.
Old May 16, 2012 | 04:05 PM
Henry89's Avatar
Henry89
Thumbs up
Called and talked to Wanaryd today. Yep! Dyna beads were used. So that cleared everything up. Thanks!
ecir40
Sep 11, 2018 11:09 PM
pat.h
Sep 28, 2014 11:03 AM
stev0n
Jan 27, 2011 07:01 AM
rbabos
Jun 14, 2009 01:09 PM
gblass1
Sep 22, 2008 06:20 PM
