05 night train, 200mm ?
Old Nov 16, 2015 | 06:23 PM
sparkygoatee's Avatar
sparkygoatee
Stage II
Default 05 night train, 200mm ?
I'm new here, and hope someone can give me some advise on how I can go from a 150 on the rear of my nighttrain , to a 200, and what would I need to do it?
Any help on this would be appreciated!
Thanks!
Old Nov 16, 2015 | 08:28 PM
stal94gt's Avatar
stal94gt
There is a write up on the sticky portion of the site. It uses the heartland 180 tire kit. Really a bolt on except you have to cut your fender struts off. If you want to go the full 200 tire you will have to get the narrow belt and pulley setup and replace the rear tire
Old Nov 20, 2015 | 01:05 PM
paul0311's Avatar
paul0311
Buy an 07 or higher. Just kidding. Good luck with your mod.
Old Nov 20, 2015 | 02:03 PM
Bunker Hill's Avatar
Bunker Hill
If you need a wheel/tire setup (2007) that's ready to go, let me know...
Old Nov 20, 2015 | 02:37 PM
DynaJ's Avatar
DynaJ
While the heartland kit is the best kit out there you can get the rsd kit for A LOT cheaper same gig on the 05 you will need to cut off the factory orns (easy)!! As far as the wheels go you will need a 5.5 wide wheel in the back what height you go is on you I went with this kit and I'm running a 18x5.5 also the pulley on my set up is stock...
Old Nov 22, 2015 | 12:30 PM
sparkygoatee
Stage II
Thanks for the info!
Joeynotz
May 31, 2016 08:32 PM
HDnoob
Nov 13, 2011 06:15 PM
MARROCKS
Jun 20, 2010 09:35 AM
nightrider05
Mar 14, 2010 07:00 PM
eddieflyer
Apr 6, 2007 04:49 PM
