Breakout brake upgrade
Old Jan 25, 2016 | 02:35 PM
Leggbreakr's Avatar
Leggbreakr
6th Gear
Default Breakout brake upgrade
I liked the look of the street glide brembo brakes.
So I bought a caliper on the off chance it would fit my brakeout, to my surprise it fits.
I did have to buy a set of pads for the new caliper. In my opinion it looks great.
It's a 4 piston caliper.
Old Jan 25, 2016 | 02:54 PM
zz2h33's Avatar
zz2h33
Nice upgrade
Old Jan 25, 2016 | 03:01 PM
splattttttt's Avatar
splattttttt
that a six piston caliper? Sais HD too, not brembo. Not sure you mentioned the brembo
Edit; oh, you meant the rotor. okay
Old Jan 25, 2016 | 04:20 PM
Leggbreakr's Avatar
Leggbreakr
6th Gear
Deff brembo...
Old Jan 25, 2016 | 04:30 PM
Leggbreakr's Avatar
Leggbreakr
6th Gear
thanks zz
Old Jan 25, 2016 | 04:31 PM
splattttttt
who knew?
Old Jan 25, 2016 | 04:36 PM
cpc0812's Avatar
cpc0812
I think it looks great on there. And it bolted right up which is even better. Nice.
Old Jan 25, 2016 | 04:37 PM
Leggbreakr's Avatar
Leggbreakr
6th Gear
Mine is also a abs model. No probs whatsoever
Old Jan 25, 2016 | 05:37 PM
HenryT's Avatar
HenryT
Talking to the HD dealer was told Brembo makes the Breakout (and other model) calipers for HD. The 2015 Softails received an upgraded front 4 piston caliper and larger rotor. If yours is pre 2015 sounds like a good move. Geee just noticed the SG has twin front rotors.....bro are you sure its an actual "upgrade"?? Two calipers would not need to be as beefy as a single caliper set up. But you do like the looks so that's cool.
Old Jan 25, 2016 | 08:01 PM
splattttttt
Went to see if fleabay had any, but none for the left side
