What's in your tank?
Old Feb 10, 2016 | 01:44 PM
  #51
splattttttt's Avatar
splattttttt
Could be Warp. Why I started this thread. Hoping I can learn more.
Old Feb 10, 2016 | 02:43 PM
  #52
Warp Factor's Avatar
Warp Factor
Originally Posted by Joe_G
The worry about combustion chamber deposits from E10 is unfounded. You WILL get combustion chamber deposits from your factory head breathing ports to the air filter, but I find the benefits of burning the combustion byproducts much greater than the minor combustion chamber deposits you get from ingesting a bit of oil along with the oil mist. I do not like the "road draft" circa pre-1968 systems guys often install on their Harley by running hoses from the head ports to the ground, with or with out a filter. By not applying a vacuum to your crankcase you are not properly expelling combustion byproducts and your engine will look like a pre-1968 engine with similar sludge.
The Harley system hardly applies any vacuum to the crankcase anyway. Since there are two large pistons going up and down at roughly the same time, it burps out some air (and oil mist) every time the pistons go down, compressing the air in the crankcase. It's not like the systems on most cars, which use a high vacuum from the intake manifold to pull air from the crankcase, along with a fresh air supply to the crankcase, to create a crossflow that purges more junk.
On combustion chamber deposits from alcohol, versus gasoline, I totally agree with Joe. Alcohol burns much cleaner than gasoline.
Old Feb 10, 2016 | 05:04 PM
  #53
Uncle G.'s Avatar
Uncle G.
I run my '94 Softail on either 93 octane E10 or 91 octane ethanol free gas (which has become available here in the last couple of years. Bike runs fine on either.
I do worry that I have a greater chance of getting bad gas buying premium instead of regular. Around here, premium may be as much as $.80 more per gallon than regular. That being the case, I suspect that very few people use it anymore, so nobody knows how long that premium has been sitting in the storage tanks.
Additives? Well, if I fill up near home, I'll add a dose of Star-tron to the gas, and I always add 2 oz. of Marvel Mystery oil to each tankful. Why? I guess that's the "mystery". 109,000 miles on the current motor and the heads have never been off, so I must be doing something right.
Old Feb 10, 2016 | 06:26 PM
  #54
splattttttt
That's impressive Uncle G. considering you circa 94 Harley wasn't fortified with all of the necessary bits and pieces required to withstand the apposed dangers of E10
Could it be that those treatments made all the difference?
Not bein the mechanically incline person I wish I was, I've no clue the damage that would have, or should have occurred otherwise??
Still not surprising you managed such feats, considering a few others here have achieved similar results.
Maybe Warp Factor is right!
Couldit be that Ethanol fuel really isn't all that bad afterall as long as you take the right precautions?
Old Feb 10, 2016 | 09:44 PM
  #55
jgos929's Avatar
jgos929
Originally Posted by splattttttt
Could It be that Ethanol fuel really isn't all that bad afterall as long as you take the right precautions?
DING DING DING!!!!
Old Feb 10, 2016 | 09:54 PM
  #56
JustDave13's Avatar
JustDave13
91 Chevron California swill edition
Old Feb 11, 2016 | 01:39 AM
  #57
LA_Dog's Avatar
LA_Dog
yeh Warp is right on that. hey if you want some good light reading on how the HD ECM uses lambda and can account for the different stoich of straight gas vs E10, check out page 40 on the MasterTune guide there is a cool well laid out table- actually the entire guide is a good read- the principals and tips in the guide can be applied to most all other advanced tuning products.
https://www.rbracing-rsr.com/downloads/tts_tuning.pdf
Old Feb 11, 2016 | 02:40 AM
  #58
splattttttt
Will do Dog. Thanks!
Old Feb 11, 2016 | 04:47 PM
  #59
LA_Dog's Avatar
LA_Dog
Splatttttt- pulled another gem out of my info file repository- really good well laid out doc on how HD EFI works, fuel lambda vs stoich, etc. good simple terms but plenty informative enough to grasp it.
http://www.808networks.com/pub/EFI B...ley delphi.pdf right click it and 'save as' to save the pdf to your computer, 4mb
Old Feb 11, 2016 | 05:30 PM
  #60
Joe_G's Avatar
Joe_G
LA Dog thank you for this!! I know how FI works pretty well but this is a nice primer indeed!!
