2003 88 Fatboy engine upgrade
Old Feb 12, 2016 | 07:28 AM
Jal's Avatar
Jal
5th Gear
Default 2003 88 Fatboy engine upgrade
Can i replace my 88 engine with lets say 96 engine, or should i use 96 kit?
Old Feb 15, 2016 | 03:53 AM
Hudson76's Avatar
Hudson76
I think you'll find the 96-103's are very different from the 88's. The way the trans and primary mount have a different bolt pattern so I believe. Might be cheaper/easier to rebuild yours to a 95"-98" with cams and head work. Plenty of good kits out there for this. Good luck mate. Let us know what you do in the end.....
Old Feb 15, 2016 | 08:45 AM
tbonetony06's Avatar
tbonetony06
2006 Deluxe, 95" with high compression pistons and manual release. Head work on my SE heads, 2" intake, 1.63" exhaust. Perfect fit pushrods, reaper 574 cams with cam plate and oil pump upgrade. Dynojet 5 auto tuner. 39" baffle less Samsons. SE 6 speed. It really lights off when I jump on it. Good luck.
Old Feb 15, 2016 | 08:53 PM
Savage3006's Avatar
Savage3006
When i Upgrade my 88 I will be doing a 95 kit. I wouldn't want to try a transplant of a 96. That would take a bunch of cash and some serious labor to get all that to work on the older frame. Way easier to change the pistons and jugs.. throw in some cams and tune it up. Can get some Nice hp/torque numbers with the 95 kits.
Old Feb 15, 2016 | 08:58 PM
QC's Avatar
QC
A 98" kit from Scott at Hillside is the answer here.
chrome-dome-dave
Jul 4, 2016 12:22 PM
shuggy39
May 21, 2012 04:42 PM
cpc0812
Nov 16, 2011 05:42 AM
jrfernandez7
Aug 2, 2009 10:54 AM
sal1269
Exhaust System Topics
Aug 8, 2006 12:33 AM
