Broken frame
Old Feb 15, 2016 | 10:25 AM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by 99%er
Looks more like the mount than the actual frame and should be fixable.Mount looks cracked and bent inward.The oil filter looks squeezed and might have prevented further engine migration.
We might not be looking at the same thing. That tab is an engine mount and is no where near the oil filter. For the tab to move inward the opposing tab on the other side would have to be bent outward. Even in that rare (if even possible) event the distance between the tab and oil filter would always be the same. I think the wire on the down tube is obscuring a complete view of the oil filter and that may be what you're seeing.
OP, take some really close up photos of the mounting tab. I still say it isn't cracked. But, without a closer view no one can really say with any certainty.
I say this for your own peace of mind and to cut off the "Softail Frames Are Breaking" thread at the pass If it was mine and I couldn't see a crack in anything put the powder coat I'd clean it up good and spray some rattle can bed liner on it and down that void at the top of the bracket.
Old Feb 15, 2016 | 01:02 PM
HGMC_GB's Avatar
HGMC_GB
doesnt looked cracked to me. looks like a powdercoat issue
Old Feb 15, 2016 | 01:10 PM
im's Avatar
im
The picture lacks sufficient detail and angle makes it rather difficult to determine.
It looks like it was welded on the side tab shown but not on the top of the tab.
Leaves someone to wonder if it was welded on the other two sides.
The photo angle also plays tricks in making the engine seem like it is closer to the frame.
Does not look like a cracked or broken frame per picture provided.
Old Feb 15, 2016 | 01:45 PM
rk1997's Avatar
rk1997
At work we'd either x-ray or UT it as thousands of my welds have been in my 42 years of welding experience. But at home I'd haft to sand it out and look at it if I thought it was a crack. We need a better pic because I don't see a crack in those.
Good luck
Old Feb 15, 2016 | 02:50 PM
oct1949's Avatar
oct1949
I also agree with not a cracked weld.. as a retired Millwright/welder for 36 yrs it looks to be either a missing weld or parts that didn't fit correct or line up right before the end weld..
Old Feb 15, 2016 | 03:57 PM
the blob's Avatar
the blob
I see no cracks.
Old Feb 15, 2016 | 06:29 PM
Durango Dave's Avatar
Durango Dave
Originally Posted by JeffJA
are you sure its not the powder-coating cracking and flaking off?
Originally Posted by Nomadmax
I'm not there but it doesn't look cracked to me.
Originally Posted by Tom84FXST
Originally Posted by rk1997
I'm sorry but I don't see a crack..
Originally Posted by the blob
I see no cracks.
I think we have a consensus, you and the shop that you took your cycle to must be mistaken. We experts on the internet must know better. Either that or a photograph is not as good as inspecting the frame in person.
Old Feb 16, 2016 | 10:46 AM
racerkvn's Avatar
racerkvn
Why did your shift lever get stuck?
Old Feb 16, 2016 | 11:16 AM
Campy Roadie
Because his frame was cracked
Old Feb 17, 2016 | 01:50 AM
NoRegerts's Avatar
NoRegerts
I've just been sitting back watching the comments. Sorry about the pics, there was too much exposure for my cell phone to handle and the reflections look like I was saying that was the crack.
Anyway, I've had a shop inspect the frame and they have confirmed the crack is a separation of the weld to the motor mount. Technically not a cracked weld, but still, cracked frame. I also had an adjuster inspect the bike, and he confirmed that there was no crash damage, which makes sense, considering I haven't crashed the bike.
I'm taking the bike to Harley tomorrow, I guess that's today then, and drop it off for inspection. I've contacted Customer Service at the MoCo and they said to take to the dealer to be inspected.
Worst case is I'm going to be responsible for the repair. I'm hoping it's nothing a tig weld can't fix.
As far as what year the bike is, I see my signature is no longer there. It had everything and I took for granted it was there when I posted. It's a 2011 Cross Bones with 31,000 miles on the ODO.
