91 SOFTAIL
Old May 11, 2007 | 04:25 PM
GAMETRACKER's Avatar
GAMETRACKER
1st Gear
Default 91 SOFTAIL
do i have to remove the outer & inner primary to change the rear drive belt on my softail ? any details will help a lot. thanks
Old May 11, 2007 | 04:39 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: 91 SOFTAIL
If I were you I would get hold of the service manual for your year bike.
It will detail EXACTLY whatneeds to be done for virtually anything on it.
And oddly enough they are fairly well laid out.
Kind of a nice change from many manuals I have been stuck with.
Old May 12, 2007 | 09:50 AM
MikeyB's Avatar
MikeyB
I'll second the manual. You will also have to remove the swing arm for belt R&R.
Sometimes I wonder if it's better to have a belt drive primary and a chain drive??
MikeyB
Old May 12, 2007 | 04:19 PM
harleyb's Avatar
harleyb
4th Gear
Yes. Remove the outer primary, the entire primary drive, the inner primary, and the swing arm pivot bolts. Don't remove the swing arm itself, or the shocks. When you reinstall the inner primary...make sure you loosen the motor mount bolts and the transmission mount bolts. The front " ears " on the inner primary break real easy if ANY misalighnment takes place. You'll have to remove the 2 starter bolts from the right side to get the inner primary off. You don't need to remove the starter completely though, but you do need to remove the bolt holding the starter jsck shaft to the starter.
Getting a manual is excellent advice. I would get the factory manual...not a chiltons or some other manual. If you don't already have them, get both an inch pound and foot pound torque wrench, and use them on everything without exception.
Harvey
Old May 15, 2007 | 12:53 AM
LOUD LARRY's Avatar
LOUD LARRY
6th Gear
I have a 95 fxstc. You need a service manual and a parts manual, the parts manual has exploded views of all parts showing how they are assembled. Very helpful!!!!!!!!!!
Old May 19, 2007 | 07:14 AM
johnnyvaughn's Avatar
johnnyvaughn
Stage III
I would sugest not doing burn-out's or pulling the front end up. I've broken many!
My bro's ask me,"How do you do wheelees with a FULL DRESSER?
I go through belts!
lndeatr
Nov 4, 2016 06:10 PM
cometnut
11
Jul 25, 2013 10:50 AM
Bohemian
Shovelhead
Sep 22, 2012 06:50 PM
Mountainkowboy
EVO
Feb 7, 2012 03:16 PM
bigsofty
May 7, 2010 10:05 PM
