Hi Rocker B, I want install in my Rocker C the turbine chrome wheels from the breakout model. I think I can install the rear wheel without problem, plug and play, but with the front wheel....I dont know if its necesarry install new tree or only i must change the spacers, i dont know.
Not 100% sure about that but I guess the Breakout and the Rocker have different axles....and if you swap for a Breakout axle you would need to change your left fork leg, too. I would check with a parts finder first!
Yes, he will need a longer axle, but the diameter is the same, so I think the forks are fine...
If he was to swap the Rocker axle for a Breakout axle he will need to swap the left fork leg too. Right side diameter is the same. I used a chromed right fork leg of a Rocker on my Breakout...the left fork leg of the Rocker would not fit due to a larger axle diameter compared to the Breakout. I had to buy a CVO fork leg instead....very pricy.
But you're the one who can tell for sure having both bikes in stock
YA, not sure why, aren't the axles both 25mm??....but I do (now) remember another member saying there was an issue with the axle when he put a turbine on his Rocker (with wider triple tree). I think he either found a axle that worked, or had one machined to fit, pretty sure he didn't change a fork, but I could be wrong....that might be another less expensive option.
The one on the BO for sure is 25mm. If I remember correctly the shape in terms of diameter steps is different on both. A Breakout axle does not fit the left Rocker fork leg.
Maybe Valdemar could have a BO axle turned down to fit?? (he has to buy a new axle either way). That would cost a lot less then a new fork..
