i have just purchased a 2003 deuce console along with
a analogue speedo and tach and 2003 indicator beze led thingo
(genuine Harley stuff speedo plug and play no problem there
but the indicator oil light neutral bezel that sits below speedo
i cant figure out how to wire it in to suit the rocker wiring
any help i would appreciate it immensely
Originally Posted by 4emmalah
ps i forgot to mention my bike is a 2011 model
thanks glen
Hi Glen, and thanks!!!.... Both consoles have a similar bezel and the same 5 indicator lights. I don't remember having an issue with the wiring... I know the new led lamp assembly came with the wires attached, and if I recall correctly, I made the connection at the large 12 way pin housing, I believe I disconnected the wires going to the Rockers indicator lights at the 12 pin, and pluged in the wires/pins from the new lights....The 12 way, pin, housing is part part #21 here... http://partsfinder.onlinemicrofiche....=46&c=0&d=2009 FXCWC SOFTAILŽ ROCKER CUSTOM™ (JK) INSTRUMENT ASSEMBLY
EDIT: I think I see the problem, I checked the parts finder and the '11 has a different pin housing part # than the one used on my '09, and its only a 6 way pin. I'm guessing you don't have a spot for black ground wire from the new lamp assembly?? I see you started a thread, hopefully there's someone here that's done this mod on an '11 and has a fix.....
Hi Glen, and thanks!!!.... Both consoles have a similar bezel and the same 5 indicator lights. I don't remember having an issue with the wiring... I know the new led lamp assembly came with the wires attached, and if I recall correctly, I made the connection at the large 12 way pin housing, I believe I disconnected the wires going to the Rockers indicator lights at the 12 pin, and pluged in the wires/pins from the new lights....The 12 way, pin, housing is part part #21 here... http://partsfinder.onlinemicrofiche....=46&c=0&d=2009 FXCWC SOFTAILŽ ROCKER CUSTOM (JK) INSTRUMENT ASSEMBLY
The 11's are CAN Bus bikes, so that adds a whole new element to electrical mods.
hey is that a breakout rear end by chance, that's what im doing right now, if ANY of the painters call back, whats wrong with these guys they gave a price I went down the lined and ook'd all of them withen 4-5 days or estimate, and no one even calls back, easy money? primed Harley rear fender from Harley, not looking to go crazy? maybe you have a reliable painter? or anyone, sorry no threadjack intended/.....btw like sarah said, we need a vid of you opening up them gears?????
Looks like a Heartland kit....and he's in Australia, hopefully you'll get a recommendation for a painter a little closer to home.
Its being painted now, that equalizer badlands, forgot which part number, does that help front and back, as I want led blinkers on front, going with a set that has them built into mirrors, clean it up, not like yours, but the covers are clear, and its chrome so well see, know that part number off hand, ill need for leds I bought for rear, running and brake, than I will pop custom dynamics leds bulbs into stock bullets,thats the plan.hope he gets paint right,i wanna hear a ride along thread that must sound BEAST
Cool man, glad you found someone....The Badlands module for the Rocker is "plug and play" and will take care of front and rear LEDs. The install instructions list it as part # ILL-01-R, but that # wasn't on the packaging.
