Fatboy neutral issue
Old Mar 25, 2016 | 05:38 PM
FatKen's Avatar
FatKen
Default Fatboy neutral issue
I would guess this has been covered before, but maybe somebody can help a guy out. I have a 2015 Fatboy Lo and though I love the bike I do not like that neutral is impossible to find when the bike is running! I would love to be able to roll up to a stop and let my hands relax a little. Does anybody have a fix or tip to find neutral?
Old Mar 25, 2016 | 05:46 PM
riknbeth's Avatar
riknbeth
Interesting. We have the same problem on our new 2016 Fatboy Lo S. Been riding for awhile so I don't think it is user error. I almost always go into neutral at a light on my Breakout, never an issue. Sorry, don't have an answer for you, but you are not the only one.
Old Mar 25, 2016 | 08:18 PM
stal94gt's Avatar
stal94gt
When I changed over from forwards to boards I put the shift lever right against the mount. The extra drag May have made it hard to find nutral. Also the lever on the forward controls has a different angle on the lever. It looks different so it may have more/less leverage by design. I just swapped levers to see if it helps
Old Mar 25, 2016 | 08:30 PM
RANGER73's Avatar
RANGER73
Check primary fluid level, also I found that raising my idle helped a lot.
Old Mar 25, 2016 | 08:49 PM
Gommee's Avatar
Gommee
Devil's Advocate
Before i removed the heel shifter, I used it to get my 2014 Lo into neutral. I found that was the only thing I used the heel shifter for and after I caught my pants on it once, it was gone.
I also changed the tranny fluid to Ams V-Twin Tranny fluid. It is thicker than 20/50 and made it a lot easier to put into neutral.
Old Mar 25, 2016 | 10:22 PM
He11Bent's Avatar
He11Bent
6th Gear
Have a 16 S now, last bike was a 14 Lo.
Both were pretty difficult to hit N.
Changing both my primary and tranny fluids to aftermarkets helped a lot, going to an extended shifter lever made it almost hard to miss. The extra leverage of the longer toe shifter lets you move it with less force and more precision. I never even THINK about missing neutral anymore, it's just "there". If your stature lets you get some use out of the longer shifter arm, it's a great mod for comfort as well...
Old Mar 26, 2016 | 05:34 AM
Warp Factor's Avatar
Warp Factor
It's usually easier to get into neutral if you do it while you're still rolling, before coming to a complete stop.
Old Mar 26, 2016 | 05:39 AM
FatKen's Avatar
FatKen
I will try some of the ideas suggested here once it gets nice enough to ride again. Maybe after the bike wears in a little more also. I only have 100 miles roughly on the bike so far.
Old Mar 26, 2016 | 06:58 AM
uklauren's Avatar
uklauren
Florida Crew Moderator
My 12 Heritage took until the 5000 mile service to be able to find neutral easily. No problems on my Fatboy S from the start. 9200 miles on it already.
Old Mar 26, 2016 | 09:35 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Usually neutral gets easier to find after a couple thousand miles. You can also try synthetic oil. It seems to work for me. Still it is never simple, just a bit easier.
