Fatboy neutral issue
Old Mar 27, 2016 | 10:12 AM
user 46092's Avatar
user 46092
Originally Posted by splattttttt
What's in a name? LOL
Shakespeare is still alive! ... and his name is splattttttt!
Old Mar 27, 2016 | 10:26 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Biji
actually HD says its for safety coz they don't want their bikes on neutral while on running.
Where did you hear/read this????
OP:Make sure the primary lube is not too high, keep it so that it barely touches the lower part of the clutch assembly, or even a bit lower.
Old Mar 27, 2016 | 10:33 AM
load97's Avatar
load97
Let it break in some more. That's bout it.
Old Mar 27, 2016 | 10:42 AM
FatKen's Avatar
FatKen
Never had a bike that I had a issue with before. Didn't really think I needed to break it in.
Old Mar 27, 2016 | 11:11 AM
splattttttt's Avatar
splattttttt
is what it is LOL
Old Mar 27, 2016 | 11:14 AM
amkaos's Avatar
amkaos
I too face the same, actually HD says its for safety coz they don't want their bikes on neutral while on running. So what we have to do is just a tap, don't give any pressure, a light tap will take you to neutral. Hope it will help you guys.
You're joking, right?
Old Mar 27, 2016 | 11:22 AM
FLS103's Avatar
FLS103
Have not read all the replies but what Dan says is true. Too much primary fluid will cause clutch drag. Also, if your clutch cable adjustment is off nuetral will be hard to find and shifts will be harder. I would start with a good clutch adjustment, check primary fluid level and check cable adjustment.
Old Mar 27, 2016 | 12:07 PM
splattttttt
Originally Posted by fls103
have not read all the replies but what dan says is true. Too much primary fluid will cause clutch drag. Also, if your clutch cable adjustment is off nuetral will be hard to find and shifts will be harder. I would start with a good clutch adjustment, check primary fluid level and check cable adjustment.
qft...
Old Mar 27, 2016 | 01:50 PM
psrb191921's Avatar
psrb191921
From: The planet that is the farthest from the bright center of the universe
Speaking in talkbass.com language: "what is the best oil for metal?" thread
Old Mar 27, 2016 | 02:57 PM
splattttttt
Molybdenum disulfide
