2003 softail with 103 questions
My friend has a 03 night train he just replaced the cams oil pump lifters and pushrods.
Heat cycled the cams in after we primed the oil pump. Seems like he is getting a hesitation on throttle . It clears up at 3500 up. Running SE 258 cams. These are new cams but the same cams he was running before his cam shoe took out his cams and oil pump. Any input would be appreciated.
Since this is an '03 using SE parts, I am going to assume that it was a dealer flash due to the EFI being a closed loop system. A retune would not help and/or hurt anything IF the cams were exactly the same.
It is possible that the cams inside the box did not match the label on the outside of the box. Did the markings on the new cam match the old cam exactly?
+1 on re-tune, and definitely +1 on making sure the new cams were an exact match / not wrong ones in the box- if the cam events (intake / exhaust open and close) in the tune ecm code are different than the cam installed, you'll have issues like this. A good way to check is if you have a powervision or other tuner with real time display, see what the MAP reading is at idle - should be around 30 range. I'd also datalog a bit to see what is happening at the hesitation areas.
Make sure the pushrods were adjusted with proper preload on the lifters, usually .140 after finding zero lash. Good luck hope it is minor and it gets sorted.
