Not Sounding Right
Old May 15, 2007 | 10:49 PM
crossfire3006's Avatar
crossfire3006
Default Not Sounding Right
Hey everyone, I need some help. I'm not too mechanically saavy and would welcome any ideas or suggestions. I have Sreamin Eagle II's on my 2002 Deuce.Lately, whenever I let off the throttle (in any gear), my exhaust makes a sputtering sound. It does it sometime when I'm shifting gears as well. Any help would be much appreciated. Thanks everyone.
crossfire3006
Old May 15, 2007 | 11:22 PM
Strgzr's Avatar
Strgzr
Default RE: Not Sounding Right
Mine pops a little especially when shifting. Not all the time but sometimes. Depends how fast I come off the throttle. If it were really lean, it would do this much more I think...
Old May 16, 2007 | 12:00 AM
crossfire3006
ORIGINAL: Strgzr
Thanks for the reply Strgzr. I'll look into my mixture.
Old May 16, 2007 | 12:01 PM
06nighttrain3130's Avatar
06nighttrain3130
I just had my 1000 mile service and had the stage 1 installed I already had the Sreamin Eagle II's on it. I asked the mechanic about the some thing yours is doing and he tells me that if I would add a Power commander that it will eliminate some of that if not all of it but it has something to do with the fuel mixture. I know my bike pops allot when I let off the gas and I have the bigger injectors the 25. Make a big difference.
Old May 16, 2007 | 12:23 PM
Soft06's Avatar
Soft06
My .02 cents.
I had the same issues with my 06 Standard until I added the Power Commander USB III.
It was mostly on decel that my bike would pop,,pop,,bang, pop. The bike is getting all air at that point with my RUSH slip on's, and the SE air cleaner kit. After the install of the PC USB III I had the machine dyno tuned and it still did it some. The mapping just needed a little fuel added to the
0% throttle column.....( I learned all this from the nice people here on the HD Forum ) at different RPM ranges..so when I roll off the throttle the bike isn't sucking all air, there is a little fuel there so the bike isn't so lean at 0% throttle in those RPM ranges.
There is more than one EFI management system out there that will solve these issues. Do a search, talk to others, gain information so you can make a choice to what is best for YOU and your bike. Keep in mind,,if you have the 07 model there were some issues with the PC USB III and a hesitation problem. I don't know if that has been resolved as of yet..??
Good luck, and..
Ride Safe
Old May 16, 2007 | 07:18 PM
crossfire3006
ORIGINAL: Soft06
My .02 cents.
Good luck, and..
Ride Safe
Thanks a lot Soft06. I just might look into the PC.
Old May 16, 2007 | 07:19 PM
crossfire3006
ORIGINAL: 06nighttrain3130
Thanks for the reply 06nighttrain3130.
trackerman
Exhaust System Topics
Oct 17, 2014 09:55 AM
Runawayisland
Jan 18, 2013 03:12 PM
flapjack kasey
24
May 4, 2010 06:18 AM
MJR
Dec 23, 2007 05:41 PM
crossfire3006
Jun 27, 2007 10:37 PM
