Foot Gear Shifter
Old May 10, 2016 | 02:24 PM
Deluxe Fatboy's Avatar
Deluxe Fatboy
Default Foot Gear Shifter
I have a 2015 Deluxe and sometimes when shifting out of 1st to 2nd my lever seems to move down or slip down and I cant get my foot under it to shift up. I have to use my heel shifter. This happens sometimes but not all the time. Is there something loose in my shifter?
Thanks!
Old May 10, 2016 | 05:42 PM
RandyL's Avatar
RandyL
you are supposed to use your heel shifter.
Old May 10, 2016 | 06:52 PM
S.D.M.F's Avatar
S.D.M.F
Thanks!
Adjust the position of the forward shifter so its higher, that way you will always be able to get your toe under it if you choose not to use the heel shifter.
Old May 10, 2016 | 07:13 PM
Axle1980's Avatar
Axle1980
What he said. If the lever itself is somewhat loose you will also correct that issue.
Old May 10, 2016 | 07:44 PM
MacSmacky's Avatar
MacSmacky
While you're adjusting the position of the toe shifter, you should remove the heel shifter. Sucks when your pants leg gets caught on it, don't ask how I know...
Old May 11, 2016 | 08:29 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I pulled the heel shifter off my bike. Needed the extra room on the floorboards. I also had to move the toe shifter to clear my boots. Easy to do.
Old May 12, 2016 | 07:10 AM
cocky's Avatar
cocky
I put an extended heel shifter on and I am now good to go.
Old May 14, 2016 | 07:44 AM
Tampa Fatboy's Avatar
Tampa Fatboy
+1...
Old May 14, 2016 | 08:37 AM
Len Turner's Avatar
Len Turner
Didn't like the heel shifter either.
Old May 14, 2016 | 12:00 PM
HDmikie's Avatar
HDmikie
Yep, same here......took off heel shifter. Only difference is I put on a chrome spacer to move the toe shifter out about 3/4 inch. Now, don't have to curl ankle inwards to shift.
