Do ya really need those frame protector when jacking up your softail?
I know... I know ... they recomend it and i will if you all think its a good idea to but the darn jack just fits under the frame as it is.
Frame protectors? What are those? I have lifted my bike numerous times and didn't know HD sold something so silly
They are actually spacers that fit between the jack and the frame to prevent lift pressure on the rear shocks that hang just a bit lower than the frame. I guess you havent had a problem without them. Sofar sogood?!?
I use four 4" long pieces of 3/4" heater hose split to fit over the rail.
That being said the $25 spacers have been on my Christmas list for years but nobody's bought it for me yet.
I can't count the times I've jacked up my '03 Heritage from service to detailing. I never gave it second thought. Then I read a debate on an HD forum (maybe this one, I forget) about whether or not these spacers are necessary.....
I decided to watch as I jacked up my Heritage and there was a small amount of flex on the shocks as the bike went up.......
Whether it will do damage I guess is another debate, but watching them flex I keep thinking.... that can't be good for the seals or pistons....
I never thought/heard about using heater hose or I would have given it a try.
I ended up buying the HD spacers and the orange color helps me to remember to remove them.
GOOD MOVE ON YOUR PART. I BOUGHT A SET AT HD FOR $15.xx ABOUT 7 YEARS AGO RIGHT AFTER I PURCHASED MY FXST. A GOOD INVESTMENT. DO I ALWAYS USE...NO. BUT I DO USE WHEN I PLAN ON A LOT OF BIKE MOVEMENT. NEVER HAD AN ISSUE WITH THEM OR WITHOUT THEM. THEY HAVE NEVER SLIPED, COME APART OR MOVED IN ANYWAY. IN ADDITION TO PROTECTING THE S/T SHOCKS THEY SUPPLY MORE STABILITY BEING FLAT. NOW I HAVE FLAT SURFACE AGAINST FLAT SURFACE. I MODIFIED MINE TO BE MORE USER FRIENDLY BY MAKING FOUR OUT OF TWO...NOTCHED TO FIT FRAME IN CERTAIN PLACES. BY THE WAY, I LEFT MINE ON A COUPLE OF TIMES AND RODE OFF. THEY WERE STILL THERE WHEN I RETURNED HOME. FRAME FIT IS EXCELLENT. SO...FWIW
