Working on installing truwrapz
Old May 15, 2016 | 07:26 PM
matte's Avatar
matte
Default Working on installing truwrapz
So I have been installing the custom dynamics truwrapz to my breakout. Instructions are easy, but running into a problem. I will call them tomorrow, but just thought I would check here to see if anyone else had something similar. I ordered the ones that run as DRLs and flash amber when the signals active. So far, no DRL and only seeing a flashing amber when I hit the signal. I'm thinking they sent me the wrong pack which would be slightly annoying because I'd rather not have to re-run the lines. thoughts?
Old May 16, 2016 | 05:06 PM
matte's Avatar
matte
So the wraps work fine. The blue light is supposed to be hit and is getting no power. is there an easy way to check these fuses on the breakout?
Old May 16, 2016 | 06:43 PM
matte's Avatar
matte
Figured it out. Hot wire was loose inside the switch housing. Just breed to sry it so it doesn't easily budge.
Old May 17, 2016 | 07:41 AM
matte's Avatar
matte
So quick question regarding the hot wire dilemma. If I wanted to reseat that wire in the switch housing, is there any specific method to doing that? I've pined over the service manual, but nothing detailed enough to see how those wires connect in there.
Hey Man
EVO
Sep 21, 2017 03:21 PM
chopprman23
Jul 2, 2017 11:37 PM
Mark M
Electrical/Lighting/Alarm
May 21, 2016 09:23 AM
jimsuver
Aug 21, 2010 04:33 AM
AngryAmish1163
Jul 8, 2010 08:43 PM
