Horn Relocation for FLSTFBS
Old May 18, 2016 | 02:57 PM
Hellbilly562's Avatar
Hellbilly562
Originally Posted by Dorsai
Murphy's Law's #7: Everything takes longer than you think.
The bar is bolted top & bottom, so disconnecting it is the easiest part.
The entire coil relocation only took two beers, so it's not a major PITA.
The horn relocation was another beer, but only because I already had the tank off so it was easy to run the wires.
Awesome...thanks for the info and tips....DK Products makes the plug and play relocation kit so I think I'll just put that on my list.....I have the ABS as well, so the horn wasn't an issue? I'm presuming I can use the current horn mount for the front....hell...I might even go with the old school look up under the front light....
(on a side note...this forum is full of ****ing awesomeness...)
Old May 18, 2016 | 03:05 PM
Hellbilly562
Murphy...better hope I never run into his ***......
Old May 18, 2016 | 03:12 PM
gchristopher9's Avatar
gchristopher9
Like Gaz B I was able to make a bracket to utlize one of the unused tapped holes and tuck it in behind the trans
Old May 18, 2016 | 03:20 PM
Hellbilly562
Yeah...I think I'll go that route as well...thanks guys.....
Old May 18, 2016 | 04:23 PM
Gaz B's Avatar
Gaz B
Just want to say Thank You Gaz. As if I didn't already have enough to do this weekend with the Honey-Do list, now I have to find time to fab up a bracket, pull the gas tank and move my horn down there.
That is an exceptional idea for locating the horn. Now I remember why I read all these threads.
Easy is a relative term with Harley's. It wasn't too bad compared to other 'easy' jobs, but I did add a bit of change to the swear-jar.
Of course, after I finally had it all out and was feeling really proud of myself, I looked at the directions again and saw where they said "if you encounter difficulty removing the bar disconnect the shift linkage".
Naturally, I have my Man Card, so directions are optional...
You're most welcome and I'm glad to of helped.
Looking forward to a progress report!
Gary
Old Jun 1, 2016 | 01:35 AM
user 46092's Avatar
user 46092
I relocated my horn to the same spot as Gaz, but the sound from that little horn is pathetic.
Old Jun 1, 2016 | 01:18 PM
Dorsai's Avatar
Dorsai
I also moved my horn to the same spot that Gaz turned us onto over this past weekend.
And since I had to pull the tank off to relocate it, and had a spare Stebel air horn laying around, decided to go full 'Belt AND Suspenders' and mount it too.
Right now the Stebel is between the downtubes, but just saw on another thread where the OP put his down by the left pass foot peg, so once I fab a bracket, it will be moved also.
Attached are some pics of the process. And don't ask for any measurements on the bracket - it was fabbed completely by-guess-and-by-golly, trying to work behind the pipes.
Attached Thumbnails Horn Relocation for FLSTFBS-horn_jumper.jpg   Horn Relocation for FLSTFBS-feed_wires.jpg   Horn Relocation for FLSTFBS-bracket_side.jpg   Horn Relocation for FLSTFBS-bracket_top.jpg   Horn Relocation for FLSTFBS-horn_bracket_back.jpg
Horn Relocation for FLSTFBS-horn_bracket_top.jpg   Horn Relocation for FLSTFBS-relay_mount.jpg   Horn Relocation for FLSTFBS-relay_complete.jpg   Horn Relocation for FLSTFBS-oem_horn.jpg   Horn Relocation for FLSTFBS-air_horn.jpg
Old Jul 22, 2016 | 01:49 PM
user 46092's Avatar
user 46092
My horn stopped working, second one of these horns from DK that went bad- and I need to pass inspection. Now I have to put my horn and coil back where they were. I'm really pissed off! I would stick my OEM horn on the front frame down tubes but I have an engine guard and they would interfere with each other.
Old Jul 22, 2016 | 05:25 PM
Gaz B's Avatar
Gaz B
Can you use the OEM horn in the new location?
Old Jul 22, 2016 | 11:11 PM
jtarter's Avatar
jtarter
This is where I put mine after the coil relocation. I used the original horn bracket and turned it in to be centered with the coil.
