Stripped the back end down. After some figuring out decided on removing 5mm (sorry for the metric measurements lol) off the caliper tab on the swing arm and the same off the outside face of the caliper/axle locating arm.
Had to remove some metal from the other end of the caliper to allow clearance to the alloy wheel and some from the inside off the swing arm for pulley clearance. This metal is actually from the belt guard bracket and not the swing arm itself.
