My Softail build
Old May 20, 2016 | 05:16 AM
NTA's Avatar
NTA
You’re doing a good job,nice color …
Old May 20, 2016 | 08:40 PM
langwilliams's Avatar
langwilliams
lookin good....that 200 tire with that fender will look sweet
Old May 21, 2016 | 02:56 AM
Hudson76's Avatar
Hudson76
Thanks guys. I appreciate the feed back. I'm still deciding to either weld on new frame horns or try the late model bolt on ones............ I don't know if they will be wide enough on my early frame.
Old May 21, 2016 | 05:57 AM
Fatboy Brian's Avatar
Fatboy Brian
Looks great...
Old May 21, 2016 | 04:57 PM
nellis003's Avatar
nellis003
Nice work. I posted about this but wanted to ask - did you have to offset the primary or trans?
Old May 21, 2016 | 05:43 PM
paul0311's Avatar
paul0311
Color looks great. Updates?
Old May 21, 2016 | 07:54 PM
Hudson76's Avatar
Hudson76
Hi Nellis, No I didn't need to off set either. The rear wheel (the wider one) actually is off set slightly to the right side, designed this way from the factory.
This, I've heard from a Harley Technician, is to compensate for the weight of the primary sticking out to the left side of the bike.
The off setting of gearbox/trans is only on the older EVO equipped bikes from what I've been lead to believe.
I only took the primary off mine to replace the old wide belt with a new narrow one (20mm) to fit the rear pulley and allow for clearance between the tyre and belt.
Old Aug 2, 2016 | 09:38 PM
Hudson76's Avatar
Hudson76
Wheels back on with new bearings and Avon AV72's
Attached Thumbnails My Softail build-heritage-nearly-finished-1.jpg   My Softail build-heritage-nearly-finished-2.jpg
Old Aug 2, 2016 | 11:32 PM
dfwhockey17's Avatar
dfwhockey17
Looking good Man! I see (primary guts pic) you get your shop towels at the same store I do!
Old Aug 2, 2016 | 11:43 PM
Hellbilly07's Avatar
Hellbilly07
Awesome man. I love seein' stuff torn apart. Means somethin' awesome is happenin! Well, hopefully lol lookin good. Keep those pics comin
redmosquito1
Apr 30, 2013 08:51 AM
Reaper22
Aug 30, 2012 09:17 PM
HGM
EVO
Apr 30, 2010 08:18 PM
9512valve
13
Apr 18, 2010 06:55 PM
jrsmith_80
Aug 5, 2008 04:54 PM
