Low idle/stall HELP!
Old Jun 13, 2016 | 07:16 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Give the Engine Temperature Sensor and the Variable Speed Sensor a once over and see if one of those is possibly the problem.
Old Jun 14, 2016 | 01:53 PM
Hazmattthecat's Avatar
Hazmattthecat
2nd Gear
Okay so here is my theory, PCV is sending me a new unit warrantied. But while I've had my bike opened up without my tuner it of course has been running extremely lean. So, I'm thinking its a safety my bike is doing, since it's running so lean it's getting a lot hotter than it usually would, so when it gets hot it goes into safety, TPS and IAT codes go off and bike shuts down. Once my bike is cooled off and is safe for itself to operate, it fires back up as if nothing is wrong. When I get my commander back the end of the week I'm going to test this theory out and see if just getting it not leaned out will solve my problems.
Old Jun 19, 2016 | 06:09 PM
Zanthamos's Avatar
Zanthamos
There are 3 modes that the computer will operate the fuel mixture in depending upon temperatures read at the temp sensor in the head. These are at 320F the ECM will reduce idle speed to cool down, at 338F the ECM richens the mixture to add extra cooling, and at 356F the ECM which stops the fuel injector pulses to attempt cooling. Should either of the latter 2 modes go into effect the IAT or the TPS codes should not be happening. I would give the 2 components the full test that they need to determine if one or the other is faulty otherwise look at the ECM itself. There is a published test in the service manual to determine if they are faulty. P0113 indicates that the IAT is either open or high resistance and the P0123 indicates that the TP has high resistance. I would look at the harness as well, maybe when the engine is hot it is causing issues in the harness. I would check the black/white striped wire coming from the TP as the IAT is also tied into the same wire going to the ECM (5V Sensor Ground). This same wire supplies the ground for the MAP and the Engine Temp sensors as well, main connector to the ECU may be a good place to start looking, if nothing else use the multi-meter and check continuity between that pin (pin 26) and the wire on each of the sensors, maybe there is a recessed pin or a loose connector somewhere.
Old Jun 21, 2016 | 01:53 PM
mswing1234's Avatar
mswing1234
Mr Krawfish (the orginal poster or OP) would have probably liked to have kept his own thread going...
Old Jun 24, 2016 | 05:58 PM
Krawfish's Avatar
Krawfish
Stage IV
Default Found the problem
Originally Posted by Krawfish
2003 Heritage Softail EFI 58K miles, Andrews 26's PCV SE II slip ons and intake. Been having a problem where the bike will run fine no speedo issues or anything else but out of no where it starts idling real low and sometimes will stall when i pull the clutch while rolling to a stop. I read a bunch of different forums which promted me to clean and change the Idle Air Control but that didnt fix it either. Anyone have any advice? I was thinking of chasing this rabbit by changing Vehicle speed sensor and engine temp sensor.
So my guy couldnt stand that he couldnt find the problem so he kept at it. During his chase he tighten the primary chain which is when he found out that the compensator nut was loose causing the bike to loose voltage. This was then causing it to idle low and stall some times. Hope this help some one that may have the same problem I know it could have saved me about $60-70.
Old Jun 26, 2016 | 01:23 PM
Zanthamos's Avatar
Zanthamos
Glad to see that you got the situation worked out.
Old Jul 16, 2016 | 09:18 AM
Hazmattthecat
2nd Gear
The synopsis was my ecm, the PCV shorted out causing the exam to fry. Power commander won't back anything up, even though they warrantied out my PCV. Other than that I will never recommend anything with dynojet in my life. I played the role correctly, could've costed me over $700. I spoke with dynojet reps and didn't get anywhere what so ever. Took my bike into the dealer and it was skeptically confirmed. Needless to say I ripped the PCV off and just flashed my new era, put 2,000 miles on my bike since and no problems.
Old Jul 16, 2016 | 03:45 PM
Hey Man's Avatar
Hey Man
Highjackers are worse than oil threads. At least the O.P. seems to have gotten his stuff squared away.
OakMountainRider
Jun 24, 2022 10:04 AM
WarBaby1946
May 7, 2014 05:09 PM
louisianaSVT2001
Oct 31, 2011 06:53 AM
128auto
Jul 11, 2011 08:27 AM
glide2005
May 25, 2009 08:56 AM
