Weird Electrical Issue
Old Jun 5, 2016 | 05:26 PM
Bleachey's Avatar
Bleachey
Default Weird Electrical Issue
'02 Heritage Softail Classic, 23k miles. New to me a couple of weeks ago, I've only put about 300 miles on her so far because it's a second bike to me and for my son to ride occasionally. So I'm out for a short errand run today and the bikes dies as I am rolling to stop with the clutch in. Fires right back up. One of the stops on the list was fill up the bike, so I thought maybe I was a little lower than I originally thought and the gas just rolled away from the pickup in the tank. I fill her up and head to the next stop. It does it a couple more times. Finish my errands and I'm headed home and I look down, speedo stuck at about 48 MPH, no odometer and no dash lights. My son rolls up next to me at the light and says he can barely see my brake lights. Get her home. The oil light comes on when the bike isn't running, but no dash check engine light, no turn signals, or turn signal indicators on the dash. I hear the fuel pump wind up when I turn it on and it fires and idles just fine.
My initial thought was maybe the voltage regulator. I don't have a manual yet, will try and pick one up in the next day or so. Anyone have any experience with a similar issue? I was going to start with the basics, check the battery, check the VR, stator and look for maybe a pinched or corroded wire.
Thanks for any input.
Old Jun 5, 2016 | 06:25 PM
Bone Doc's Avatar
Bone Doc
Congratulations on the new bike. The Heritage is a fine machine.
Electrical issues can be tricky. Is the bike throwing any codes?
As you suggested, start simple.
1. Check the battery with and without a load.
2. Make sure the battery cables are not loose at the battery and ground.
3. Check the voltage regulator
Some of the symptoms you describe are indications of a bad vehicle speed sensor (VSS).
Vehicke speed sensor (VSS)
Others will chime in with their thoughts.
Old Jun 5, 2016 | 06:49 PM
Bleachey's Avatar
Bleachey
Well I'm not sure about the codes, and with the odometer being blank not sure how I would read them? I will pick up a manual at lunch tomorrow and check all the above, thank you very much for the input!!!
Old Jun 5, 2016 | 06:56 PM
checkers's Avatar
checkers
As stated, check and clean battery cables, incl ground. If battery is old or suspect, replace. The battery is the heart of electrical system, start there.
Old Jun 5, 2016 | 09:44 PM
Zanthamos's Avatar
Zanthamos
I would check all of the connections below the console after checking the battery, maybe a loose connection is causing the issue. . .
Old Jun 5, 2016 | 10:02 PM
IRON1250's Avatar
IRON1250
Sounds like a ground issue. Be sure to check the frame end of your ground cable.
Old Jun 6, 2016 | 09:58 AM
racerkvn's Avatar
racerkvn
Pull the switch out and take it apart, then clean all the contacts, springs and bridges. Swap the worn contact/spring and bridge from the "ON" position to the "ACC" position.
Old Jun 6, 2016 | 10:07 AM
Bleachey's Avatar
Bleachey
I will try this as well, should be able to find some instructions or videos on how to remove the switch, no manual yet, thought i would have a couple months before I needed one!!! It is on order though.
Old Jun 6, 2016 | 10:37 AM
racerkvn's Avatar
racerkvn
It's pretty easy. Pull the dash up and unhook all of the connectors to remove the dash (you don't have to remove the dash but I find it's easy to do and less likely to scratch something). Then remove the 4 screws holding the switch to the dash (5/16" socket I think). You'll see a big clip on the back side of the switch, push the middle of the switch in to relieve some pressure on the clip and remove the clip. Once you're that far you'll see the contacts, just remove them one at a time and clean them really good with a wire brush and install them back where they were. You'll easily see the worn contact compared to the others and it's position, move that bridge and spring to another position and move the "like new" bridge and spring from that position to the "ON" or worn position. Then reassemble.
My 02 Heritage started doing very similar things about the same mileage and traced it to the switch being worn and making light contact. Although it has nothing to do with the model of the bike or the mileage on the bike as much as it does from that amount of use.
Joe G did a really nice write up about the switch. I'll try and find that thread and add the link in just a few minutes.
Here it is. Joe is the man!
https://www.hdforums.com/forum/softa...le-riding.html
Old Jun 9, 2016 | 08:54 PM
Bleachey's Avatar
Bleachey
Appreciate all the advice, it was incredibly helpful. I removed and cleaned the switch. Didn't fix the problem. Looked over battery connections and all visible wires, looked good. Found a blown fuse. Went ahead and replaced it, hoping it was just old. Fixed the issue, temporarily as feared. After a short 10 minute ride it blew again, and this time the left turn signal is staying on. Now I get to chase a ground or pinched wire somewhere. Fun!!! If the old lady doesn't want to go out tomorrow night I will do it then, if not my Saturday is booked.
