2002 Fatboy shut down while riding
Old Jun 12, 2016 | 04:19 PM
WVleo's Avatar
WVleo
Default 2002 Fatboy shut down while riding
Hi, My 2002 carbed Fatboy shut down today while on a main road going 30mph. Just lost all power and coasted bike to the side of the road. Checked all fuses good even cleaned all for good connection before putting them back in. Had battery tested as thought it was shot but tested fine at autozone . put tester on all fuses once reinstalled all good. Headlight does not come on but brake light does. Never had any issues before with this bike ! When i got back from Autozone and hearing the battery was good i was hoping it was the kill switch . Nope was in the run position ! Just towed it home and now scratching my head........ WVleo
Old Jun 12, 2016 | 07:28 PM
the blob's Avatar
the blob
I'd check and clean the ignition switch on the tank. Then if
Not I'd look at the main circuit breaker by the rear wheel.
Old Jun 12, 2016 | 09:30 PM
langwilliams's Avatar
langwilliams
here's the thread about cleaning the switch....also check/clean your grounds to the frame
https://www.hdforums.com/forum/softa...le-riding.html
Old Jun 15, 2016 | 10:30 AM
WVleo's Avatar
WVleo
thanks for the suggestions. Cleaned and gently greased the ignition starter switch with dielectric grease. Replace 30amp breaker with 50amp breaker from dealer ( what they had in stock ), cleaned and greased battery connections making sure they were tight. Fatboy started right up !!!! Now need to take it for a test ride locally to be sure its fixed.......WVleo
dillmanrandy
Feb 9, 2017 07:47 PM
gavdar
May 16, 2014 11:46 AM
Hrlyric
Aug 2, 2013 05:21 PM
92CigarBob
Jul 4, 2013 09:40 PM
smittyc
Oct 21, 2012 07:58 PM
