Shotgun shocks
Old Jun 28, 2016 | 10:21 AM
schlacker's Avatar
schlacker
Originally Posted by DynaJ
I can tell you that the shotgun is a great product but my biggest complaint is the inability to adjust quickly. A preset switch would be a major plus in my book, but I can't stand adjusting air anymore.
Yet another reason I'm avoiding SS. When I factor in the cost, the install, adding air hoses, compressor, electrical work, this thread about transmission oil changes, plus other things that could possibly go wrong, I have to wonder if it's really worth it.
I don't even think I'd take one if it were given to me & installed free.
JMHO
Old Jun 28, 2016 | 10:24 AM
hspring03's Avatar
hspring03
I can adjust very quickly... And I solved the transmission change issue...... I installed the Shotgun on an EVO...
Old Jun 28, 2016 | 12:27 PM
Village Idiot™'s Avatar
Village Idiot™
JMHO
Really it's easy. You'd have to be severely mechanically dis-inclined to not be able to install one by yourself. The "electrical work" is running a harness which plugs in where needed. The compressor may be the hardest part if you have to tap the screw holes. That's very easy and can be done with hand tools and the taps provided. The "air hoses" is one line that plugs into the compressor and runs maybe 2 inches to the shock.
The biggest reason would be having to deal with the failures, returns, and down times because of it.
Old Jun 28, 2016 | 09:26 PM
schlacker's Avatar
schlacker
I appreciate the counterpoint "Village Idiot" I really want one, but I'm going to need someone with your experience to talk me into it.
Old Jun 28, 2016 | 10:34 PM
amkaos's Avatar
amkaos
once you understand the switches, adjustment takes seconds.
And easy to repeat the settings
Old Jun 29, 2016 | 04:16 AM
peg20's Avatar
peg20
I found that the ABS version of the Shotgun has a smaller compressor which can't get the pressure up as high as the standard version. It used to take me several minutes of holding the switch on to get the shocks firm enough to ride pothole-ridden UK roads. (I am 165lb and this is riding solo, no luggage.) I could never get the suspension firm enough for "spirited" riding through twisties.
(But then I used to ride sports bikes. I used to have the stock shocks firmed up quite a lot further than suggested in the manual, and run progressive monos up front with all the clips in, so perhaps my appetite for firm suspension is greater than average?)
Old Jun 29, 2016 | 05:26 AM
EagleRay's Avatar
EagleRay
There is an upgrade/replacement available for those "insufficient" ABS version units. AFAIK all the new units come with the improved compressor and don't suffer this pressure issue anymore.
Old Jun 29, 2016 | 06:00 AM
peg20's Avatar
peg20
That's good to know. But I've been there, tried that. Unlikely to go back. Just got fed up of fiddling with the settings when I just want to ride the damn thing.
Old Jun 29, 2016 | 02:36 PM
jam436's Avatar
jam436
When mine was new I couldn't resist the temptation to play with it all the time, like the example mentioned above, slamming it every time I parked it...
Once the novelty wore off I just set it where I liked it and haven't touched it since - it hasn't budged in two years, except for maybe twice a year, at the start and end of riding season, when I dump the air for winter storage and again in the spring when I raise it back up...
Old Jun 29, 2016 | 06:27 PM
Village Idiot™
I ride slammed everywhere but the interstate. So I'm up and down a lot. I know where It gets set though.
