Help removing my grips
Old May 21, 2007 | 11:02 AM
tmwilkin's Avatar
tmwilkin
Stage I
Default Help removing my grips
I'm going to attempt to install the heated grips this evening, but was curious. How is the left grip generally install on the harley's. It was clear so I wasn't sure my approach for removing it.
Any tips/advice ?
Old May 21, 2007 | 11:11 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Help removing my grips
On newer bikes they are held on with the switch housing.
On older bikes (pre 2000 I believe)they are forced or glued on and just a really tight fit.
Old May 21, 2007 | 12:13 PM
oldgeezer's Avatar
oldgeezer
Generally, they are glued on. Just cut it off and throw it away. Clean all the excess glue off the bars before installing the new grip.
Old May 21, 2007 | 01:43 PM
Helix's Avatar
Helix
On my sportster and Dyna all I ever did was grip it with both hand and squeeze and twist Counter Clockwise then rock mit clockwise till it breaks loose. Comes off In like 10 Secs.
Old May 21, 2007 | 03:38 PM
texfatboy's Avatar
texfatboy
if you have a air compressor, you can get a air blower and blow compressed air under the grip between the grip and handlebars while pulling on the grip. the air will break the glue loose and it will slide off.. good luck. kerry
Old May 21, 2007 | 03:58 PM
NC Pirate's Avatar
NC Pirate
I just cut a slit down the middle with a razor blade, and it peeled right off........
Machine213
Jul 16, 2018 04:51 PM
davey019
Milwaukee Eight (M8)
Feb 20, 2017 02:39 PM
kanddr
2014-2024 Touring Models
Aug 31, 2014 10:25 PM
paulies 07
Oct 24, 2008 08:16 PM
testifer
May 13, 2008 03:33 PM
