Stupid reflector removal question
Old May 21, 2007 | 07:24 PM
OscarsSoftail's Avatar
OscarsSoftail
Default Stupid reflector removal question
Just a quick stupid quesiton on getting the reflectors off of the rear fender on my 2004 Std. What can I use to get the glue off from the double sided tape as to not screw up the paint? Thanx
Old May 21, 2007 | 07:31 PM
Cruiser 1970's Avatar
Cruiser 1970
Default RE: Stupid reflector removal question
I use mineral spirits or Goo-gone (sp). Lighter fluid or WD-40 will work also.
Old May 21, 2007 | 07:44 PM
OscarsSoftail
awsome. thanx
Old May 21, 2007 | 09:57 PM
FXSTD.AU's Avatar
FXSTD.AU
I used a tar and bug spot remover, then washed both front and rear areas down immediately i was fiished just tobe on hte safe side. That with a bit of effort got the adhesive of the front forks, but i found the rear adhesive was just easier to peel off if it was heated.
Old May 21, 2007 | 10:03 PM
copterdoctor64's Avatar
copterdoctor64
I'm in the same boat.. Front reflectors just needed a little Sticker and Label Remover, and the backs just a little elbow grease.
Old May 21, 2007 | 10:21 PM
[Hooligan]'s Avatar
[Hooligan]
I just removed mine finally last week. GooGone worked awesome. Put it on and let it set for a bit... then it wiped off with very little work.
Old May 21, 2007 | 11:54 PM
BoneCrusher's Avatar
BoneCrusher
I just used a heat gun and it peeled right off. I peeled the remaining tape off with my fingers and it was almost spotless.
Old May 22, 2007 | 09:36 PM
panamoncreel's Avatar
panamoncreel
Hair Dryer and then Goo Gone and the first couple layers of skin rubbed off my thumbs.
Old May 22, 2007 | 09:56 PM
eravo's Avatar
eravo
Goo Gone Spray worked really good for me...
Old May 24, 2007 | 12:10 AM
Nasty350LT1's Avatar
Nasty350LT1
ORIGINAL: Gundog
Boy O Boy is your spelling OFF...
It's called "Goof Off"
I use it all the time.
