"I did not use a load equalizer, signals flash at normal rate"
wonder if that's the case with my older evo electrical system...they work well with that short fender....My 99 fatboy is so clean I'm really fighting temptation to start changing stuff left an right! Fat rear tire, small fender, wide springer front end...
If I keep checking out stuff like your bike I will end up changing it!
is the housing made of metal or plastic? I've been wanting led's on the back for my stop/turn bullets, but the bulbs never fit. Always longer than they should be.
Housing is machined from solid aluminum, they are made well .
