I believe that almost any pull back risers should fit as all of them use the same size mountings.
You might be able to get away with the stock cables, but the hard brake line will probably have tobe replaced for something a little bit longer.
Finally thought; screw it, and am getting new bars, cables etc.
I find the stock FatBoy bars are way too far forward for me. I did loosen the risers and turn the bar back about 5 mm and that has seemed to help. You may want to try that in the mean time.
On the site they say....... "Low-profile risers accentuate the fattened 1 1/4 internally wired handlebar"..... etc. etc.... I for one am not crazy about the low-profile risers.
Fred, I know HD does not make pullback risers for your bile since they are 1.25" in the middle. I have an adaptor kit so you can use Wild 1 Chubby handlebars with your stock risers and clamps. I also have the Chubby bars.
Johnny Vaughn www.hdbikeparts.com
