'99 Fat Boy... suspension options
Old Aug 24, 2016 | 07:59 AM
b1pig's Avatar
b1pig
4th Gear
Default '99 Fat Boy... suspension options
Hey guys.
'99 Fat Boy. Suspension is stock. Fork oil has never been changed.... but the seals are good. 18,000 miles. one of the rear shocks does seem to have a leaking seal on it.
My question.
What are my best options for obtaining a decent ride out of this bike? My wife recently had to have back surgery, so this is important to us. The forks are pretty soft, but the rear end is nearly as bad as riding on top of a brick being dragged down a city street in New Jersey.
I've seen some air ride (pricey) systems online and i've also noticed that Progressive Suspension has some options. Together, the wife and I are around 380 lbs. I can probably screw around with the rear end and see if the preload is cranked all the way up, but since one is leaking anyway, I'm thinking of scrapping both and getting something else.
So.
Options? Experiences? I'm open to anything that will keep me from getting punched in the ribs.
Old Aug 24, 2016 | 09:06 AM
misfitJason's Avatar
misfitJason
Progressive springs up front with ricor intiminators. Works shocks in the rear. Don't lower it. Blam. Done
Old Aug 24, 2016 | 09:53 AM
b1pig's Avatar
b1pig
4th Gear
Sounds similar to what I was looking at for my KLR650. LOL.....
Is this the set you're referring to? http://www.jpcycles.com/product/701-261
So far, thats the only thing I've found from them.
Old Aug 24, 2016 | 11:28 AM
tommyglide's Avatar
tommyglide
I have Works on my 09 Softail, different shocks for the later years tho. Consider calling Works with your issues and they can also advise what to do up front. Smart guys there.
Old Aug 24, 2016 | 01:04 PM
misfitJason
Yes those are the ones
Old Jul 13, 2017 | 07:38 PM
b1pig's Avatar
b1pig
4th Gear
So. A year later. A couple of months ago, I pulled the bike out, put it on a lift and had a look at it. Short version. Previous owner installed lowering links. At least since 2006. Probably longer. They also seemed to be nearly ALL the way out. My attempts to shorten them back up failed as the threads galled up and rendered them useless. One of my coworkers heard me talking about it and called in a favor to a friend of his that works for a bike salvage yard in another state.
Got a set of used shocks free of charge sent my way. I slipped them on and I can't tell you what a difference it made. It is no longer painful to ride. LOL....
Learning as I go with this thing.
Old Jul 13, 2017 | 09:44 PM
langwilliams's Avatar
langwilliams
I picked up some "new take offs" works shocks on ebay for under $300 shipped but they weren't build to my specs...Some chopper shop gets frames with them an remove the works for air ride.
on my 99 fatboy I drained the forks an mixed half standard weight HD oil an half "screamin eagle race" oil....I guess 10 weight an 20 weight....the old oil looked orig to me, it was nasty....front ride quality was improved just from that.
eratz
Aug 16, 2017 09:35 PM
Slick12
Feb 22, 2013 10:45 PM
Mike Willmont
Feb 23, 2012 08:59 PM
U-234
May 9, 2010 01:05 PM
Hamperdiver
Jan 8, 2007 04:32 AM
