Fatboy Lighting
Old Sep 4, 2016 | 11:19 AM
SHARP1983's Avatar
SHARP1983
Default Fatboy Lighting
I've got a 2010 Fatboy Lo that I'm am always riding. I do alot of night riding, (work 2nd shift) and I'm looking for some additional lighting. I went from OEM bulbs to a HID kit and now on too a Truck Lite 7" LED which is Awesome on high beam but low still leaves much to be desired. I'm fixing to add a bullet fairing so a light bar and passing lamps are a no go so do you guys have any suggestions for some lighting?
*I do also have a complete HID H4 bulb setup that can be used if need be*
Old Sep 4, 2016 | 11:33 AM
bigblock59's Avatar
bigblock59
I hated the hid light on my fatboy. Light pattern scatters to much. Do you have a crash bar? You could mount some lights on there or get some clamp on lights for the front frame down tubes. You could also use the custom dynamics sunspots? I think that's what they are called. They are white and turn yellow when you turn on the turn signals.
Old Sep 7, 2016 | 04:35 PM
98fat's Avatar
98fat
Add an engine guard (crash bar) and some lights. The Rigid Lights SR-Q2 are an extremely bright driving light with a high and low.
Old Sep 7, 2016 | 10:18 PM
Snowyone's Avatar
Snowyone
Spring for the new JW led lights. Heard they're awesome and expensive.
Old Sep 7, 2016 | 10:37 PM
sire86's Avatar
sire86
I installed this bulb on my 2010 FB , easy install, very bright. $69.95
Part Number: CYRON-ABH4K-A6K
Cyron Lighting H4 LED Retrofit Headlight Bulb Cyron.com
Get the advantages of LED light for your motorcycle headlight at a fraction of the cost. Why replace the entire housing when you can just replace the lamp and save hundreds of dollars. Retrofit, Do Not Replace!
Keep your existing custom headlight, Save money
Fits 90% of Motorcycles
Kit includes 4 adapters for many make/models
Bright White Beam, 6000K
Superior color contrast in all road conditions
LED Technology
Low power draw will not drain battery
20,000 Hours Life
Active Heat Mangement System
DIY Installation
Simple retrofit kit, Built in ballast
Wide Operating Voltage
Remains bright regardless of battery condition
Hi/Lo Dual Beam
High and low beam in one bulb
2000 Lumens Output
copter827
May 16, 2018 06:52 AM
Fatboy103
Feb 25, 2013 05:55 PM
spinoleo
Jan 1, 2013 09:35 AM
AmericanMuscle
Jul 3, 2012 09:10 AM
Navy UC Rider
Aug 24, 2011 11:23 PM
