2004 HD Fatboy
Old Sep 20, 2016 | 11:45 AM
taknbyu2's Avatar
taknbyu2
Stage I
Default 2004 HD Fatboy
I have A 2004 Fatboy that when ever I shift gears either up or down the shifter gets stuck in that position. I have to push it back down to continue shifting up and pull it back up when I shift down. I am hoping it is a easy fix. Help please!
Old Sep 20, 2016 | 05:19 PM
krispy12's Avatar
krispy12
Stage III
Check the fluid, might be low?
Old Sep 20, 2016 | 10:42 PM
the blob's Avatar
the blob
Id say luble the whole shifter assembly.
Old Sep 20, 2016 | 11:38 PM
Zanthamos's Avatar
Zanthamos
You probably have a gummed up shift pivot. I had the same issue on my 2005 Deluxe, it is a quick and easy fix to remove, clean, and lube the pivot bolt and bushings.
Saltyvet77
May 31, 2017 06:28 AM
cdremy
General Topics/Tech Tips
Apr 2, 2017 07:35 AM
Mannw1989
Feb 12, 2017 09:14 AM
2011 fatee
Jul 4, 2014 03:08 PM
oldschol
Sep 25, 2005 04:17 PM
