Oil leaked from bike
Old Nov 20, 2016 | 10:01 AM
HDmikie's Avatar
HDmikie
Originally Posted by harleyL7
Thank you for all the replies. I will check it for any splits or loose connections. It's a fatboy lo, my bad I forgot to mention that.
Yep, my Fatboy also leaked from the drain hose. There was a crack right at the elbow. Like someone said, remove the plastic tire guard to make the awkward job a lot easier. And use worm clamps instead of the cheap pinch clamps.
Old Nov 20, 2016 | 10:17 AM
1004ron's Avatar
1004ron
And the year?
Old Oct 15, 2017 | 06:44 PM
Motley Mick's Avatar
Motley Mick
Stage IV
Originally Posted by Rocker B
It's called an "oil tank drain hose"....might be leaking at the clamp, or the hose may be cracked.
Rocker B, My Oil Drain Hose is cracked and seeping oil. Do you know if there is a braided Oil Drain Hose for the Rockers (& Part #)? I've been searching and can't fine it. Thanks.
Nickd2689
Jun 19, 2017 08:06 PM
four4fish
Jul 25, 2015 02:13 PM
provp88
Jul 25, 2011 07:39 AM
rodney123456
Oil Archive (no new posts)
Oct 12, 2009 04:42 PM
WARG
Aug 15, 2006 12:27 AM
