Deuce Forks Width
Old Nov 18, 2016 | 08:58 AM
PurpleShark's Avatar
PurpleShark
Default Deuce Forks Width
Hi all,
I've come by a screen from a Deuce in "as new" condition that I would like to fit onto my softail standard. I believe the fitting kit i need is 58397-00 as the 4 mounting "bobbins" go in-between the forks & not outside like the normal softail screen.
Before I order the kit could someone with a Deuce measure the width of the forks from centre to centre? My forks are 41mm which seems to be fine and the triple trees are far enough apart (top to bottom) and so it's just the fork width I need to check (the Standard ones are 9 3/4" ish).
Thanks, Jayne
Old Nov 20, 2016 | 02:13 PM
07DeuceTX's Avatar
07DeuceTX
Hi Jayne, hope this helps. I walked to my garage, peeled back the cover far enough to snap a shot of my '07 Deuce front forks. Yeah, center to center is in the 9 3/4" range you mentioned. Best of success with the install!
Old Nov 20, 2016 | 03:07 PM
PurpleShark
Brill and many thanks.
Jayne
eviltwin69
Aug 15, 2015 01:12 PM
Village Idiot™
May 7, 2014 01:53 PM
red deuce
May 4, 2012 01:52 PM
rounder
Jul 19, 2008 08:32 PM
Triztyn
May 27, 2008 09:41 AM
