06 Heritage Classic
Old Nov 23, 2016 | 10:11 PM
Mark Roettgen's Avatar
Mark Roettgen
Stage III
Default 06 Heritage Classic
Right side turn signal is not flashing in front but flashes in rear. When I hit switch the indicator flashes 3 time normal then rapid flashes in rear as stated but does not flash in front at all. Lights up but that's it. Any suggestions on a cause. Thanks Mark
Old Nov 23, 2016 | 10:49 PM
bad tappets's Avatar
bad tappets
Welcome!
Try replacing the bulb. Rapid flashes are usually a bad bulb.
Old Nov 24, 2016 | 01:07 PM
Mark Roettgen
Stage III
Default Thanks for the welcome!
I have tried the new bulb tip a while back thinking it was the easiest route with no luck. I found bald wire last week and repaired that also and still nothing. If you are in a pitch black room you can see it flashing up front but unless it's dark and your an inch away from it you'd never notice.
Old Nov 24, 2016 | 04:24 PM
bad tappets
Probably a bad connection/wire somewhere. Find the correct wire, and check for continuity/resistance. May take some time, but eventually you'll find it. Check socket first, as it's easy to get to. Also might try cleaning socket, and using some dielectric grease on the bulb before you put it back in.
Old Nov 24, 2016 | 07:36 PM
Mark Roettgen
Stage III
I'll give it a shot and let ya know how it goes, thank you.
t.thompson259
Electrical/Lighting/Alarm
Feb 25, 2015 04:38 AM
Hclassic2012
Sep 17, 2014 09:42 PM
UltraDuff
Mar 14, 2014 09:40 AM
lt1tyrell
Oct 4, 2010 03:05 PM
skooter
Oct 29, 2007 11:32 AM
