Breakout Peg Scraping
Old Dec 1, 2016 | 09:29 PM
RedHogz's Avatar
RedHogz
A lot of good advice here. If I was the fellow looking to mod his Breakout and avoid dragging the pegs, I'd seriously go the route of easing up a bit in the corners. Personally, my cafe racer days are long gone and to prove that to myself I almost crapped my chaps the first time I ground the Heritage's floor boards into the asphalt riding two up. That never happened on my FXR, Sportster or numerous metric thrills. If the geometry of the machine isn't designed my the MOCO to corner hard, then experimentation is at your own risk. Be careful.
Old Dec 3, 2016 | 11:40 AM
ChromeSpark's Avatar
ChromeSpark
Yep they scrape. Till you get rid of feelers, then your boot heel scrapes or if pushed hard enough you can scrape pipes and frame, if you want....but why do all that?
Old Dec 3, 2016 | 01:53 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
My pegs have hit the pavement at some point because of the way the ends look but I never felt it. I normally don't lean that far over, so it surprised me when I saw it.
Old Dec 3, 2016 | 01:57 PM
FurryOne's Avatar
FurryOne
Because it's FUN!!!
Old Dec 3, 2016 | 04:04 PM
ChromeSpark
Exactly! Drag on.................
Old Dec 3, 2016 | 04:31 PM
HenryT's Avatar
HenryT
Yeah, the feelers are there for a reason. They are an early warning that says lean much more and hard parts will be scraping soon. Leave em on IMO.
Old Dec 3, 2016 | 06:49 PM
TOMMYBLAZIN's Avatar
TOMMYBLAZIN
I Have a rocker, which im SURE doesn't corner as good, and I can dip real good with it now, after you ride it SLOW learn the limitations like stated , than push the envelope as far as your skill set, before Harleys I rode rick rockets, doing 100mph wheelies Standing up!!!., anyway, I almost lost it taking it home, after a few months, I can take it thru a mountain of twisties just fine, a tiny scrape here and there, but I wont lean it as far as to scrape the pipes, ill go with a cheap 10k ricer if I want that effect, im building a work of art currently :^) rocker/breakout, literally.
Old Dec 5, 2016 | 02:28 PM
Mother's Avatar
Mother
Replace the peg feelers with titanium bolts and enjoy the spark show.
Old Dec 5, 2016 | 03:15 PM
Yamaharley's Avatar
Yamaharley
I love seeing sportbikes do standing wheelies down the road and if you look carefully you can tell what the tip of the exhaust is made of by what color sparks it makes hahaha.
Old Dec 5, 2016 | 03:48 PM
Rooster10's Avatar
Rooster10
Default Breakout
Originally Posted by IdahoHacker
Softails have the worst ground clearance and the worst lean angle clearance of any Harley-Davidson currently being made.
They are beautiful motorcycles, with smooth running engines, and the vast majority of their owners love them.
However, if you like to ride a motorcycle quickly on curvy roads, this is not the model for you. You can spend a bunch of money to turn it into a Dyna or a Sportster, but it would make more sense financially to buy a motorcycle that meets your needs.
Very good advice. I drove a new breakout and scraped the pegs on the first corner. Turned me right off. Loved the way it looked. Would have bought one till that happend. To each his own.
Bob
