Brembo on a Rocker?
Old Dec 28, 2016 | 03:17 PM
v-rodder's Avatar
v-rodder
Default Brembo on a Rocker?
Hey, I have been doing some research on this, and most all of the info has been on upgrading the front brakes on Sporty's and Dyna's. I've got a Rocker in route, and I know it will need better braking. Tell me if this is right:
1. Left side touring brembo
2. 11.8 front rotor
3. reuse my 9/16" stock softail front M/C
It should just bolt on. The only question is will the stock 9/16" M/C be fine, and will I need to custom order a brake line that is HD on the M/C end and brembo on the caliper end.
As for the rear, that seems like a big NO GO.
Any input would be appreesh'd.
Jim
Old Dec 28, 2016 | 04:11 PM
UT-rckr's Avatar
UT-rckr
I offer no input on whether fitting the Brembo caliper will work, but there are other aftermarket bolt on options if not.
What makes you say you know the brakes will need to be upgraded?
Old Dec 28, 2016 | 04:36 PM
v-rodder's Avatar
v-rodder
Had a rocker before. Plus I am doing a 103ci upgrade with cams. I did see where HD upgraded the front calipers on the softails in 2015.
micahpop
Softail Parts
Jun 11, 2011 08:48 PM
Hotwire
Apr 16, 2011 03:08 PM
Rocker_UAE
Feb 2, 2011 02:24 AM
reds2harleys
Jun 1, 2009 06:56 PM
Ruralmed
Apr 23, 2008 12:11 PM
