Ignition Switch Problem 1988 FLSTC
Old Jan 1, 2017 | 07:29 PM
eglide_rider's Avatar
eglide_rider
Default Ignition Switch Problem 1988 FLSTC
I have a 1988 Heritage Softail Classic. When I turn the ignition switch to Ignition, the bike will turn over and start. Signals and brake lights work. When I turn the switch to Lights, the bike shuts off. If I try to start the bike with the switch turned to Lights, nothing happens when I try to start the bike, but the lights dim a little and the signals are very slow. Everything worked fine yesterday, but today, AFU.
Electrical stuff is far from my strong suit....any thoughts on where I might start with this?????? Thanks much.
Old Jan 1, 2017 | 07:37 PM
TSheff's Avatar
TSheff
Remove the negative battery cable
Remove the switch and clean all the contacts - reconnect the battery and test it.
You've identified it starts and runs until you change the switch position, so it's either the switch, or other terminals and wiring associated with the lights.
Old Jan 1, 2017 | 07:50 PM
81rat's Avatar
81rat
It really sounds like you have a ground problem , check your battery cables -- clean them follow to where they go and clean there also with sand paper or something of the same. a 88 is getting up in the years with paint rust and corrosion of alum to steel and paper gaskets you just might need to run a couple of extra ground cables say 1 from bat to starter mounting bolt and 1 from bat to frame . Clean clean all of your wire ends
Old Jan 1, 2017 | 08:28 PM
eglide_rider
Thanks guys...now I have some starting points.
Old Jan 2, 2017 | 10:52 AM
tmilo1000's Avatar
tmilo1000
If you have a volt meter, check the voltage of the battery. If it is 12-13 volts battery could be good. Check the voltage again as you try to start the bike, if it drops to 8-9 volts, battery is probably shot.
Old Jan 2, 2017 | 11:26 AM
Tom84FXST's Avatar
Tom84FXST
That tells you that the battery is good...and the ground is good.
The problem is most likely switch related. That model should have a jumper wire so the lights are on in both the ignition and light position...if not someone removed it.
First thing I would do is check the terminals on the switch, and make sure they are tight.
hell hound
Shovelhead
Jun 13, 2019 09:19 AM
Lightyear68
Mar 19, 2015 07:31 PM
kd4tsc
Aug 16, 2009 05:12 PM
Hostile1
Feb 10, 2009 03:57 PM
soulman
Apr 4, 2007 10:56 AM
