Bleed front brakes
Old Jan 4, 2017 | 02:34 PM
cencal's Avatar
cencal
Originally Posted by chrisj49
Two ways I have read to fix this - pull the lever 100's of times until the air is worked out, or tie the handle back overnight. I have never tried the second fix, but have used the first one on 2 bikes and it fixed the problem.
I tried both of these as well. nada
I have the pump and more fluid coming from Amazon. Should be here a few hours. Gotta love next/same day delivery.
Hopefully, this cures it.
Old Jan 4, 2017 | 02:38 PM
IdahoHacker's Avatar
IdahoHacker
I'd find a service manual as well. It will save you a lot of grief.
Oh, and watch a few Youtube vids before you try something new. It's amazing how helpful they are.
Old Jan 4, 2017 | 02:56 PM
btaksier's Avatar
btaksier
I had a similar issue and could not get any pressure to build after I swapped my front brake line. I ordered a generic syringe and PUSHED the brake fluid up from the bleeder valve. Worked like a champ and took one try.
Old Jan 4, 2017 | 03:08 PM
Mother's Avatar
Mother
This is the way I've done it on bikes as well. Work from the bottom up.
Old Jan 4, 2017 | 03:11 PM
btaksier's Avatar
btaksier
only issue I had was the hose between the syringe and bleeder valve would pop off. A couple hose clamps solved that
Old Jan 4, 2017 | 04:17 PM
lh4x4's Avatar
lh4x4
There is one possible answer. Being an 03 maybe at some point it was changed to dot 4 and when the dot 5 was added it jelled up. It may take a vac bleeder and lever pressure to pull it out.
I have changed all my early HD's to DOT 4 so that I do not need to carry both types and make sure that I don't need to check what I'm using. I have changed the covers to read DOT 4.
Old Jan 4, 2017 | 11:08 PM
Deucedog's Avatar
Deucedog
Yep, me too. I bought a large (big enough to hold the same amount of brake fluid as the master cylinder) syringe from a medical supply store and some plastic tubing. Empty the master cylinder of the old fluid. Put the tubing on the syringe, fill the syringe and the tubing with new fluid, put the other end of the tubing on the bleeder valve. Open the bleeder. Now push the new fluid up thru the brake line into the master cylinder. Do not pull back on the syringe as you could pull air into the line.
**NOTE: Make sure you do not overflow the master cylinder! Brake fluid eats paint big time!
I've bled brakes successfully several times this way.
Old Jan 5, 2017 | 12:48 AM
cencal's Avatar
cencal
Well I got it using the pump. Still do not have the front brake feel that I want as the lever has too much play in my opinion. However, I have never had a big bike before.....just enduro/dual sports and dirt bikes. SHould not really matter.
I guess I will get use to it. May like it better.
Old Jan 5, 2017 | 06:43 AM
Mother's Avatar
Mother
Now that you have some pressure this is the good time to zip tie the lever overnight or even for a couple days. Go out every few hours and tap on things from the bottom up with the handle of a screwdriver just to encourage any leftover bubbles to work their way up.
Old Jan 9, 2017 | 05:11 PM
Skeezmachine's Avatar
Skeezmachine
Originally Posted by cencal
Man, I have never used a vacuum bleeder before after doing lots of brakes (non on a Harley).
I have pumped that lever like 1000 times and still nothing. Frustrating.
I guess I will go get a vacuum bleeder tomorrow
I once changed the master cylinder on my Bones and simply removed the old one, installed the new one, filled it with fluid and pumped it to get it to bleed. Took a lot of pumps but eventually it worked.
Last year I completely changed out my master cylinder, brake line and removed, cleaned and reinstalled the caliper. Once I added brake fluid all the pumping in the world, leaving the line open over night, and every other home-brew kit in the world could get my line bled. I bought one of the less expensive vacuums from Harbor Freight and had the job done in 5 minutes. I guess it all depends on how much of the systems goes empty before simply pumping the lever doesn't work but apparently there is a limit.
mikebehr00
Wheels/Tires
Feb 23, 2014 11:16 AM
stbobber
Apr 2, 2011 07:00 PM
Bedore
Sep 1, 2010 09:17 PM
I8SMK4U
EVO
Oct 29, 2009 09:49 AM
fritz9690
Nov 20, 2006 10:39 AM
