Trans pulley change
Old Feb 11, 2017 | 11:30 AM
Dave0176's Avatar
Dave0176
Default Trans pulley change
I'm gonna be replacing the trans pulley with a 30 T. Is there a definitive need to remove the oil tank? Because according to the manual a TON of stuff needs to be removed including the rear fender?
Old Feb 11, 2017 | 12:55 PM
Br125's Avatar
Br125
I did not remove the oil tank or fender. Removing the rear wheel makes it easier though. You can unbolt the oil tank and move it out of the way enough to get to the starter bolt.
Old Feb 11, 2017 | 01:48 PM
stal94gt's Avatar
stal94gt
i dont know for sure but wouldnt a shorter belt be needed? there may be enough space on the rear tire adjustment to take up the extra slack but i am curious as well
Old Feb 11, 2017 | 01:50 PM
Br125's Avatar
Br125
Depends where he is in the adjuster now. I had a 70 on the rear with the stock belt, right at the end of adjustment. Now with the 30 up front I have plenty of adjustment either way with the stock belt.
Old Feb 11, 2017 | 10:08 PM
Dave0176's Avatar
Dave0176
Rear wheel is off getting tire replaced.
deadhawg
Aug 20, 2023 07:07 PM
Big Dave
Aug 7, 2017 10:04 AM
Egarrity
Oct 30, 2014 09:02 PM
nickel dime
May 26, 2012 03:33 PM
TaterBall
May 22, 2012 09:56 AM
