I'm frustrated as well. Today I swapped out a working turn signal module without alarm same result. Anther thread said to just disconnect the crank position sensor. Another fail. This bike is too mint and un-****ed with to have an issue like this. I have power at the coil just no spark. Bout ready to throw up the white flag.
hey just curious I'm have a very similar issue and I am wondering if you ever figured out your issue.. I have been running all through these forums trying to figure out the issue with my bike and have tried multiple things yet the result is still the same.. If you have figured it out... Please share!!
Still no luck. Last Saturday I ohmed out most of the ignition circuit. Checked the stator for ***** and giggles. Pulled off the manifold pressure sensor. I'm at a total loss. The guy I bought it from gave me an out. I may load her up and go get my money back.
Put a spare set of plugs in the holes and try again to see if there is spark (doing the same routine as you did). I was informed that cranking the motor without plugs in it, won't generate a spark. As dubious as it sounds, I found it to be true.
Are you talking about the ignition control module or somthing else. Can you tell me where it is. I've pretty much looked at any component with a wire hanging out of it. I'm truly stumped
OK well this is on my bike may be different for yours... On the right side of bike ICM side you should have a cover remove the two screws on that cover... Then you should have two bolts holding the ICM sensor plate in place. Make sure you mark of where the plate is mounted before removing(adjusting this can also advance or retard your timing) remove the two flat head style bolts.. Then simply push the wires up from underneath while pulling on the ICM to move out of way... You should then see the trigger rotor... With ICM out of the way turn the ignition on and try starting the motor, see if the trigger rotor spins...
