Help! Help! Help!!!!!
Old Mar 16, 2017 | 08:40 PM
easy87's Avatar
easy87
2nd Gear
fuel pump running, battery been removed more then once to check for bad wiring, yeap I'm stuck haha
Old Mar 16, 2017 | 08:44 PM
davidwruth's Avatar
davidwruth
Sorry dude. It's not that complicated of a system. Have to keep a cool head and check even the stuff that would seem to be simple and a over site. If it worked before then it should run again. Not trying to sound trite. Just have to check the simple stuff too. We often make things harder than they are.
Old Mar 16, 2017 | 08:45 PM
silveradoman2's Avatar
silveradoman2
Okay back to square one. You took the battery out to do something else. Again check connections and even better make sure that none of the lugs are broken or at least hanging on. I can't see it to be anything else.
Old Mar 16, 2017 | 08:49 PM
QC's Avatar
QC
Is the ignition switch clean and fresh?
Old Mar 16, 2017 | 09:05 PM
rowan's Avatar
rowan
Thumbs up
Did you pull the tank? If so, Check fuel line connection to the tank. Disconnect and reconnect quick connect
I had a similar issue just recently did not reconnect fuel line bike cranked fuel pump ran would not fire.
Old Mar 17, 2017 | 05:36 AM
jpowell490's Avatar
jpowell490
I had a similar issue too. It was the battery, unless it is brand new, I would replace it.
Old Mar 20, 2017 | 07:01 AM
davidwruth's Avatar
davidwruth
So does the silence mean that you found the problem?
Traffanstead
Engine Mechanical Topics
Aug 10, 2015 04:47 PM
07 street bob benny
11
Jun 15, 2015 09:49 AM
Acadian
Shovelhead
May 2, 2014 12:47 PM
jules929
Nov 12, 2012 08:40 PM
buckler27
Ironhead
Mar 26, 2008 10:13 PM
