"Wiggle" under acceleration
Old Apr 9, 2017 | 10:16 PM
tbplayer's Avatar
tbplayer
Schmeriously!! I have it reversed, as that's what the instructions for the hardbag brackets said to do, for clearance. Although it looks like there would be plenty either way.
Left the heat shields off the exhaust in case I have to drop it again. With that nut torqued down, nothing moves (no bearing/axle issues, no missing spacers). So it was just that.
Old Apr 9, 2017 | 10:18 PM
skid_pimp's Avatar
skid_pimp
I'm glad you found your problem, and corrected it. Now get out and ride safe man.
Old Apr 9, 2017 | 10:45 PM
bad tappets's Avatar
bad tappets
Originally Posted by tbplayer
Rear axle nut had worked itself loose!! Wow. Lucky that clip is on there. Alignment looks right, but being loose was causing it to shift off the adjuster under load. Checking the torque again... and should I use Loctite even on that one?
Glad you found the problem. Shouldn't need Locktite with the proper torque and the retainer clip in place.
Did you check belt tension while sitting on the bike? That's the proper method with some Softails, check your service manual.
Old Apr 10, 2017 | 12:39 AM
tbplayer's Avatar
tbplayer
I wouldn't think, but I torqued it down once, and it worked loose, and I have to drop the exhaust to access the nut. So I'd rather it not work loose again.
I checked it on the lift, with the gauge. As long as it is in the ballpark, that's all I care about.
Old Apr 10, 2017 | 07:26 PM
bad tappets
Not sure what year your bike is, but you may not even be in the ballpark if you checked belt tension with rear wheel off the ground.
Old Apr 10, 2017 | 09:12 PM
tbplayer's Avatar
tbplayer
Service manual has numbers for both off the ground and on the ground (with no one sitting on it).
Old Apr 13, 2017 | 10:41 AM
tbplayer's Avatar
tbplayer
I finally got everything put back together last night.
When I took that axle nut off, the threads had quite a bit of old grease on them. I took a rag to it, and a lot of black came off. So I got a wire brush and some rubbing alcohol and cleaned the threads off on both the nut and bolt real good. Got them good and clean, applied blue loctite and re-torqued.
Hopefully that is the end of it.
On the older models, they had a castle nut and lock pin, but on the newer ones like mine, they've gone to an e-clip. So that nut is free to loosen. The e-clip would only prevent the nut from working itself completely off.
I wonder why they did that. Seems like the old way of securing it would have been more, well, secure.
Old Apr 13, 2017 | 11:52 AM
Griff012FLHX's Avatar
Griff012FLHX
Glad ya found the problem, Funny how sometimes it's the most simple thing....
Old Apr 13, 2017 | 12:02 PM
tbplayer's Avatar
tbplayer
Well, I'll feel more confident about it after another 200 miles, if everything is still tight.
LX2
2014-2024 Touring Models
Mar 4, 2016 12:51 PM
Stricnine
Wheels/Tires
Aug 29, 2014 08:26 AM
emerican19
May 17, 2013 09:14 PM
ga guy
Jun 15, 2010 12:16 PM
Strgzr
Nov 3, 2007 04:35 PM
