07 FXSTB High Idle
2007 fxstb nightrain, power commander III, Slip-on's are Screaming Eagle.
Bought it used from dealer. I have been riding it apron 500 miles per summer form the last 3 years and up until last summer the idle has been acting up. I have no tach on it so I can only estimate the idle speed compared to my fellow bikers. it used to idle around the 1000 rpm but since last summer it is more like 2000 to 3000. I have cleaned the IAC, I have tried to reset ECM a few times and finally yesterdays after another reset ( as per a few forums where they say to turn ign switch from on to off 5 or 6 times slowly) I started the bike and idle seemed ok. Took it for a ride and after the first corner there it was again.
I had carbs in my life and know vacuum can cause problem but on FI I can't figure out from where or how I can find vacuum leak. Custom shop told me it could be the injectors?? or change the power commander. I am just scared of the price they will come up with if I bring it at the dealer. So I am turning to your help to see if I can learn and fix the damn problem.
Thank for reading
Thanks for the reply. Forgot to put it in the first post, but I did check. No kinks, bindings etc. The throttle is free and works good. I took the air filter out to make sure everything operated fine.
I did notice 2 holes in the bolts that hold the filter bracket in the cylinder heads but don't know if they play any part in my problem or not. Although I replaced the bolts back before starting the bike again.
I was thinking of investing in a new unit such as the Cobra FI2000 or Power Commander V if I can't find the problem.
The problem is only high idle. I don't remember the last time it idled normally apart from the first few month I bought it.
For the codes I will have to ask the shop since I don't have the original speedometer, but last time I brought it to the shop they did not mention any codes showing up. I heard of a code checker that is sold on amazon so I might get a hold of that for futur use.
when stopped it does not stall. It actually stays up in the 2000 to 3000 rpm, sometimes it stays around the 1200 rpm or so. As I said I have to go by the ear since I have no tach on the bike.
Turn signals work correctly for the cancelling after a turn. The flashers are after market but not the cheap chinese made stuff. Actually italien made, stuff you find on ducati i think. Speedometer is also after market, simple analog /digital but no codes on there.
One, my throttle blade shaft had cracked and broken, thus the left side was not giving proper throttle shaft information to the throttle position sensor on the left side (the cables are on the right side).
I bought a new throttle but that did not fix it properly. I tried a idle air controller but that didn't help.
The fix was a new throttle position switch. Easy to install and it's been fine ever since. I'd check for a broken throttle shaft and then try replacing the throttle position switch based on my experience.
So I guess my next step will be to check the injectors. Believe it or not I had them all ready to pull them out and I didn't, so I will have to start over lol.
Joe_G..
I might do that too, actually I almost bought the 37$ assembly to change it but decided to try the gaskets first. It's an easy fix if that is the problem. Will try that then will go for the injectors.
Thank you all for your help. will keep ya'll posted.
