wheel bearings
Old Jun 4, 2007 | 03:39 PM
greywolf77's Avatar
greywolf77
Stage III
Default wheel bearings
hi, help! fatboy solid wheels on 99 heritage- front wheel bearings will not clamp tight still got play unless i remove both thin washers and one thicker on disc side of wheel;; is this viable or have bearings worn out; also apart from buying a puller, how do you get outer shell out impossible to drift as inner lip in way both sides, thanks
Old Jun 4, 2007 | 11:25 PM
mtdave2's Avatar
mtdave2
Default RE: wheel bearings
are you sure the shaft is in far enough? many people get a drill bit the same size as the hole in the axel shaft, then tap it so it wont go anymore (with bit in hole), then put on your nut. might solve the prob.
Old Jun 5, 2007 | 10:36 AM
billnourse's Avatar
billnourse
You should have some end play in the axle when the wheel is torqued. Usually need .002 to .006". If you have too much remove shims. If you have too little, add shims. You need a dial indicator with a magnatic base to do this job properly.
As far as the bearings being worn out, if they still look good and are not scored, rusted or pitted, they should be fine. I had 80,000 miles on the wheel bearings on my '95 Roadking and they were fine.
Bill
Old Jun 5, 2007 | 04:28 PM
greywolf77's Avatar
greywolf77
Stage III
thanks for ideas, have repacked bearings , put back with two fine shims left out the one thicker washer, had to add a large washer outside of spacer to get desired effect though, now cant torque up spindle nut very hard, but wheel spins and runs no problem,maybe a thinner washer would do trick, i will keep at it, cheers;;;;;;;;;;;
Rtl4042
Wheels/Tires
Jun 20, 2017 09:50 AM
Ozark Joe
EVO
Jan 4, 2017 12:39 PM
taterbum
Wheels/Tires
Sep 12, 2015 11:19 AM
johnnythrottle
Wheels/Tires
Apr 9, 2013 07:46 AM
BungoBill
EVO
13
Aug 16, 2010 04:38 AM
