2001 heritage softail wheel change
Old Apr 23, 2017 | 10:01 PM
shark13's Avatar
shark13
Default 2001 heritage softail wheel change
Hi to all,this is my first post i"m a newbie.Here is my question,Iwant to change out my original spoke rims for the HD profile laced style.The part # I think is 43011-05 front & the rear is 43014-05. I got the # from the 07 catalog but my problem is these #s only fit 03 thru 06,nothing about 01.What can be the differences from 01 to 03?I already purchased a set from a local person that took them off an 05.I would appreciate any info to help me out.Thanks alot,& have a safe riding season coming up.
Old Apr 24, 2017 | 03:12 PM
dsalazar63's Avatar
dsalazar63
Axle size is different. I have an 05 and the axle size is 3/4". I believed they switched to 1" in 2007.
Old Apr 24, 2017 | 06:23 PM
Low budget Dan's Avatar
Low budget Dan
I think his 01 is 3/4 so the wheels he is looking at should work look for a chart on a custom wheel site they may have the info
Old Apr 24, 2017 | 09:37 PM
shark13's Avatar
shark13
Thanks for the replys.Today I did a mock up of the wheels,I took old wheels off & put the new rims on without tires.I supported the bike with my handy dandy harbour freight jack.My axles are 3/4" & the bearings installed on the 05 wheels are 3/4",brake rotors lined up too, so lo & behold everything worked out.Now I have to have tires swapped out.Thanks again & safe riding.
Old Apr 27, 2017 | 11:08 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by shark13
...What can be the differences from 01 to 03?...
The rim offset is the difference...HD moved the rim over farther to right (relative to the hub) approx another .100" away from the pulley to give more tire-to-belt clearance for the wider 150 tire they introduced in 2003
mikeskustoms
2018+ Softail Models
Feb 1, 2019 07:49 AM
smokyheritage
Aug 23, 2015 09:58 AM
LRS
Aug 23, 2013 06:40 AM
Jackazz
Oct 1, 2012 11:55 AM
stevejt99
Feb 18, 2008 10:51 PM
